Old 25-11-10, 02:46 PM   #11
metalmonkey
Default Re: Flat Battery - replace or charge?
A trickle charger is always worth while, I have one for my bike its worth the money. Is Batteryman still on the site? He did some deals for batteries, worth a PM I would have thought.
Old 25-11-10, 02:47 PM   #12
Matts-Yokes
Get a Yuasa Japan battery, dont even bother with a cheap taiwan/chinese replacement from the large wholesalers they are crap and wont last the winter. There is also a company in China called Yuasa so make sure you are buying the Japanese one.
If you buy something thats cheap **** then you get what you pay for and you will be buying another in a few weeks/months.
Old 25-11-10, 04:08 PM   #13
Originally Posted by WeegieBlue View Post
Is it YXT12BS rather than YX12BS? Can't see YX anywhere.....
My apologies Its YT12BS
Old 25-11-10, 04:45 PM   #14
embee
embee's Avatar
About the best batteries readily available are the Yuasa "YTZ" range, they will deliver significantly more starting current ("cold cranking amps" or CCA) than YTX types and the like.
The best bang for buck comes from the YTZ14S, enough current to start a 747. It is a little taller than the stock item and I believe it is necessary to remove the fuse tray (but obviously keep the fuse blocks!) though I haven't done it on my curvey. I don't use mine in winter so fitted a YTZ10S which is actually slightly shorter than stock but still more CCA. Compare dimensions on the Yuasa site.
Honda dealers have genuine ones at pretty competitive prices, though they have gone up recently, presumably India/China are buying up all the lead in the world. They cost around £65 for a YTZ14S at the mo'.
It would be worth just checking that your bike is charging properly first, lights on and rev to 3000rpm+ and you should see 14V or so, if it's significantly less it'll probably not be charging properly. Check the flow chart here .
(PS - I think the stock battery for a curvey is a YT12A-BS)
Old 25-11-10, 08:55 PM   #15
WeegieBlue
Them Yuasa ones ain't cheap are they?!? Is it really worth spending £150 on a battery? Will it be three times as good as one from Halfords for £50 or a Suzuki one at £65?
Or what about this
http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=2047
Old 25-11-10, 09:08 PM   #16
Varta's are about £50 have a look on fleabay
Old 25-11-10, 09:13 PM   #17
fizzwheel
fizzwheel's Avatar
Where are you getting your prices from ? I bought a Yuasa for my GSXR a while ago which IIRC is the same one that the curvey takes, cost me £60 ish from the local battery guy...
Get ringing around, I bet you find some more competative prices.
edit - a quick google reveals this
http://www.batterymasters.co.uk/Prod...ogle_2399.aspx
£44.58 + delivery...
Or here
http://www.mdsbattery.co.uk/shop/pro...ctGroupID=2047
£49.98 includnig vat with free delivery...
Old 25-11-10, 09:37 PM   #18
WeegieBlue
It was here:
http://www.yuasabatteries.co.uk/yuas...eries-23-c.asp
But I think they're funky gel ones.
Old 25-11-10, 09:39 PM   #19
aye thats a gel battery CCA 210A instead of CCA 110A.
If your running a lot of electrical gear (heated grips etc) invest in one
Old 25-11-10, 09:41 PM   #20
WeegieBlue
Nothing electrically fancy on my bike so I'll stick with the cheaper one. Gonna order it now and hope it arrives Saturday in the post.
Thanks for all the help folks. Karma will reward you at some future point
Question about how to charge a AGM battery. Disaster-Master Bikes - Talk & Issues 3 16-11-10 07:10 PM
And the best way to charge a battery is. . . rowdy Idle Banter 6 25-01-10 12:33 PM
First charge of a new battery. JediGoat Bikes - Talk & Issues 40 13-12-09 11:51 AM
new battery - how to charge for first time ? Warren SV Talk, Tuning & Tweaking 18 03-12-07 09:43 PM
Do I need to charge my battery? M65 SV Talk, Tuning & Tweaking 6 15-07-05 11:20 AM
