Old 25-11-10, 10:21 PM   #11
Default Re: Warped Disc :(
Classic sign is when the lever is rock solid at standstill but goes slightly squishy when you are moving. Or pulsing in the lever.
Shuddering when braking also.
Warped discs will cause first symptoms, some other things as well as discs may cause second... like pad spring being wrong behind caliper.
If in doubt measure the discs. If they feel fine when riding they probably are. Badly warped discs are f'in terrifying!
Old 26-11-10, 02:12 AM   #12
zadar
Originally Posted by DavieSV View Post
Warped disc may not give a 'pulsing' feel.
they may take a longer first pull on the lever to bring the pads back in, the second pull will be much shorter.
The wobbly disc will push the pistons further away so they will have to travel more to apply the same pressure
Warped is usually referred to disc that has bad surface, dips from heat and wear. This will give you pulsing in lever or vibration.
Everything else is bent rotor which does what you say, inconsistent lever travel.
Old 26-11-10, 10:40 AM   #13
punyXpress
punyXpress's Avatar
. . . as will slack wheel bearings.
Now: Street Triple R
Are my Disks Warped? Luckypants Bikes - Talk & Issues 10 19-03-10 02:46 PM
Warped discs? yorkie_chris SV Talk, Tuning & Tweaking 30 02-04-08 07:42 PM
Think I've warped my rear disc! Can they be skimmed? monkey Bikes - Talk & Issues 5 03-03-08 10:31 PM
Anyone know where I could find a tax disc sticker to mount the disc on bodywork? Horney SV Talk, Tuning & Tweaking 8 14-01-08 08:38 AM
Brake noise, warped disc? adw Bikes - Talk & Issues 6 21-08-07 07:33 AM
