Old 13-12-10, 12:45 PM   #11
husky03
Default Re: FAO Stretchie and GG
dizz-maybe be helpful-
http://www.landyzone.co.uk/lz/f9/3-a...de-125617.html
Old 14-12-10, 02:12 PM   #12
pegasus
pegasus's Avatar
Brake fluid - fine
Fuses - fine
Discs & Pads - fine
Take car for test drive - fine (ABS works, as does HDC)
Take brake switch apart and clean with WD40, check connections and put back in place - Hey Presto!!!
brake lights start working again.
Now just got to get diagnostic lights switched off by Mr Beaumont.
Cost so far £0.
Result methinks
tune in, turn on, burn out
pegasus is offline   Reply With Quote
Old 14-12-10, 05:40 PM   #13
fastdruid
fastdruid's Avatar
I was going to suggest turning it off and back on again[1].
Druid
[1] As in disconnect the fuse or battery, leave for 30-60sec and reconnect/replace.
Old 14-12-10, 05:46 PM   #14
_Stretchie_
Large Member
_Stretchie_'s Avatar
Could be time to invest in a Hawkeye or something similar.
Thinking about it myself for when we get an engine in the TD5. I think if you have a Land Rover with an electronic brain this should be on your wish list, especially if you use it off road at all.
Guessing it's about £50-£80 for a diagnostic check at a garage so it would probably pay for itself
How to amuze an idiot:
Look right-> <-Look Left
Old 14-12-10, 06:21 PM   #15
Its always an off road day on Halifaxs roads!!
F.A.O Stretchie.... 454697819 Idle Banter 50 12-11-09 01:38 PM
Stretchie Quedos Idle Banter 7 22-10-09 06:44 PM
Where,s stretchie ? stewie Idle Banter 8 26-10-07 10:45 PM
Where's that fo Stretchie? Anonymous South & West Surfers 8 07-06-06 07:19 PM
Stretchie...is this a 'cat? Anonymous South & West Surfers 5 18-04-06 10:25 AM
