Old 29-12-10, 06:51 PM   #11
zadar
Default Re: Lightweight lithium battery
They apparently hold charge a bit better, but that makes no odds, the selling point is the weight reduction.
I wouldn't bother unless I was building something particularly special. For something meant for the track it would be a definite.
Read this thread http://www.twfracing.com/vbforums/showthread.php?t=923
There is more than just weight reduction.
Old 30-12-10, 09:29 PM   #12
CSpronken
CSpronken's Avatar
Default Re: Lightweight lithium battery?
I have had it in my bike for a couple of months now. I bought it to make room for a Kawa shock reservoir without needing to bend the undertray. AFAIK it won't safe you 4 kg but 2 kg is normal (0.7kg vs. 2.7kg or so). In my experience they hold charge pretty good, in fact I haven't felt any difference in practise compared to the original. I feel I can tell the 2 kg diff. prolly cause the weight loss is pretty high up on the bike. Some cells can be balanced with a special type of charger, but I haven't done mine. I will check how they have held charge at the end of the winter.
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going.
CSpronken is offline   Reply With Quote
Old 31-12-10, 02:42 PM   #13
tim8061
Lots of interesting threads on this on other bike forums if you google "diy lightweight battery" - you can buy an 8-pack of A123 LiFePO4 26650 cells for around £50 on ebay which is a comparable price to a standard lead-acid, so long as you don't mind making up the leads etc. Hmmm . . where's me soldering iron?
Old 31-12-10, 04:45 PM   #14
suzukigt380paul
just weighed 2 batteries 1 of a bandit 12 and 1 of a gsx600 they both weighed about 4 kg so cant see how you can save 4 kgs,and for a £130 i could buy 3 top end gell batteries
Lightweight Rear Subframe sweepdoggydog For Sale - SV's and SV related items 3 03-07-10 07:17 PM
AA battery life, Duracells or lithium? the white rabbit Idle Banter 9 18-08-09 11:43 PM
Lithium grease Nobbylad SV Talk, Tuning & Tweaking 4 27-07-08 04:56 PM
Suspension for a Lightweight! ukhammy SV Talk, Tuning & Tweaking 15 05-10-07 11:42 PM
lightweight wheels busasean Stuff Wanted 5 11-12-05 11:35 PM
