Old 17-01-11, 10:06 PM   #11
hongman
Default Re: Jump start bike with car?
Originally Posted by TSM View Post
i just clamp negative to bike frame and then leaves me only to deal with positive terminal while handling the battery for positive connectio
Thanks for that tip, didnt know I could do that.
Originally Posted by beabert View Post
I with sid squid on this one, you wont need to start it, but it will charge if the car was on.
It will? Handy to know
Hopefully it wont come to this, but sods law and all that.
Old 17-01-11, 11:03 PM   #12
you should not charge a bike battery with high current or it can damage the battery,
For the duration of a jump start it won't make any difference.
Old 17-01-11, 11:16 PM   #13
_Stretchie_
Large Member
_Stretchie_'s Avatar
I've started the Thundercat loads of times from my 1.5 Civic and with the Civic running but not being revved.
But I was told to clamp the negative on the receiving (flat) vehicle to an earth point and not to the battery as it can upset engine management systems if present, and the Haynes book of lies backs that up, so that's what I do.
How to amuze an idiot:
Look right-> <-Look Left
Old 17-01-11, 11:20 PM   #14
benji106
Dont try and start a bike while its connected to a battery charger though or you will blow a fuse in the battery charger. Or so i have been told...
Old 17-01-11, 11:21 PM   #15
TSM
The Sick Man
TSM's Avatar
never happened to me
Old 17-01-11, 11:23 PM   #16
hongman
Lol. Unlucky
I'm nervous about my mot. Dunno why. I'm missing that rear numberplate reflector thing but hopefully he'll letme off.
Old 17-01-11, 11:27 PM   #17
The 'not connecting the neg lead to the battery' is a hangover from the days of unsealed batteries, there could be some flammable gas from the battery and if there were a spark on connecting the second lead - you do connect the leads in the right order, don't you?
Even if it were not for that, connecting the neg lead directly to, preferably, the engine ensures the least resistance in the jump circuit.
If connecting the neg jump lead to the battery made the electronics suffer so would connecting the lead to the frame/engine - the engine, battery, frame are directly connected together already, the engine and frame by being big metal things bolted together, and the battery has a fat lead that goes from the neg terminal to a bolt on the engine.
Old 17-01-11, 11:34 PM   #18
Care to explain why?
Explanation I heard that if your olde schoole shunt reg-rec was 'set' at say 13.8V and the car alternator regulated to put out 14.5V it could result in the reg-rec attempting to dump more excess energy than it was designed to and overheat it.
Bad luck, probably nothing bad happens in most cases, but plausible.
Old 17-01-11, 11:51 PM   #19
Honestly, I've tested this, and that was some years ago when such things were significantly less robust than they are now. We tried every combination of electronic and electro-mechanical device that could be found and could not make a unit fail using jump leads correctly from another vehicle.
Also I have never encountered a plausible story of failure in such circumstances, there are stories, but all that I have been faced with are accounted for with a very technical explanation: put the leads on the right way round. I will see if I can find the article into which all this testing went.
We even used two 12V batteries to apply 24V and couldn't make a regulator or electronic ignition unit fail. I really woudn't recommend that even though I know of someone on here who successfully jumped his SV from a tractor with a 24V system.
Old 18-01-11, 12:44 AM   #20
beabert
it will charge regardless anyway even with the car off as it will draw current from the car battery till its either full or balanced between
SidSquid will prolly write somthing far better to understand than me
I know that, but it was in reponse to your post saying it wouldn't lol.
Not fat enough to jump start an SV? Kylie SV Talk, Tuning & Tweaking 14 25-11-09 06:28 PM
Can I jump start my bike? krhall Bikes - Talk & Issues 17 10-06-09 06:53 PM
Jump start question. PJinUK SV Talk, Tuning & Tweaking 7 01-12-08 01:37 PM
how do i jump start my bike florida650 SV Talk, Tuning & Tweaking 32 31-07-07 09:08 AM
Can i jump start my bike with jump leads (Like my car!) Freeloader SV Talk, Tuning & Tweaking 3 08-12-05 06:46 PM
