Old 20-02-11, 03:19 PM   #11
Default Re: Spark plug as sump plug
I think that is a recipe to a motor rebuild.
I'd check wemoto they normally carry sump plugs and be quicker than ordering one through your dealer if needs to
Old 20-02-11, 04:06 PM   #12
toxic
aftermarket magnetic sump plug.
Old 20-02-11, 05:05 PM   #13
Nobbylad
Nobbylad's Avatar
Based on sound mechanical theory, or just a hunch?
To my mind, the spark plug deals with higher temperatures and harsher conditions in a cylinder chamber, than a bolt swimming in a pool of oil?
The only issue I can think of is if cutting the insulator would make it likely to leak at all.
As for the magnetic disc at the end of the existing sump plug, I've never seen any metallic dust or particles stuck to it when removing it previously.
I know I can get one from wemoto or most bike shops locally, however needed it so I could use the bike tomorrow.
Old 20-02-11, 05:07 PM   #14
I would do it as a temp fix on my bike i cant see why not.
Why cant the existing plug co back in for a temp plug? are the threads fubar'ed?
Old 20-02-11, 05:10 PM   #15
Nobbylad
Nobbylad's Avatar
Did you see the pic in post #5?
Old 20-02-11, 05:12 PM   #16
I did but didnt look at it properly, was it a proper nut or allen bolt type?
How the hell did it get to that state ?
Old 20-02-11, 05:14 PM   #17
Nobbylad
Nobbylad's Avatar
Proper nut type!
How did it get in that state?....well...that's a long story, but basically due to my doziness in overtightening it in the first place, then using a series of cunning methods from different sized sockets/grips/dremelling/hacksawing etc until I got to a point where removing the entire head to relieve the torque then extracting it was the only viable option.
Old 20-02-11, 05:16 PM   #18
Proper nut type!
Oh bugger, sounds like a mission
Stick with the spark plug as temp fix then.
Old 21-02-11, 08:48 AM   #19
haggis
I would say steer clear of the spark plug idea, even if it is a bodge for a few days. The ceramic is brittle. Have you tried cutting your favourite mug with a hacksaw? It's not gonna be a clean slice, is it?
Also, the original sump plug isn't of the magnetic tip type, so you wouldn't see any flecks of crap on it.
Old 21-02-11, 08:53 AM   #20
haggis
Get one here, they're quick at sending out. Should be with you tomorrow, if ordered this morning. They have the washer, order that too.
http://www.wemoto.com/bikes/Suzuki/S...Plug_Magnetic/
Sump Plug - where from? toby_smith SV Talk, Tuning & Tweaking 6 11-07-10 10:53 PM
Sump Plug Torque? skov SV Talk, Tuning & Tweaking 2 27-02-08 08:38 PM
Drilling Out Sump Plug? UlsterSV SV Talk, Tuning & Tweaking 13 15-04-06 05:22 PM
Pants! Sump plug... localhost Bikes - Talk & Issues 12 20-01-06 11:27 AM
