Old 25-02-11, 12:17 PM   #11
Rob969
Default Re: Speedo reading erratically.
The rotor is Item 23A here
£21.31
Old 25-02-11, 04:30 PM   #12
ryansv
Thanks for replys will have to investigate the weekend. In regards to the rev counter I think that was normal tbh.
Old 04-03-11, 05:40 PM   #13
ryansv
just been out again speedo and rev counter are being wild and bike is bumpy
Old 04-03-11, 05:51 PM   #14
xXBADGERXx
First port of call is make sure the Battery Connections are fine as you said the bike is also "Bumpy" , seem to remember a Curvy SV having the same issue a long time ago . If the bike was behaving in a smooth fashion I would then move onto the front Speedo Rotor and see how many bits that has decided to lunch itself into . If that is in bits then get a new one from the dealer or on the board here but make sure you get the correct one for your year . I went through 3 in succession on my Pointy until I examined one of the Wheel Bearings and found that the metal plate on the bearing that makes it a "Sealed Bearing" had come away a bit and was forcing my Speedo Rotors to get crushed when the tiniest ingress of muck appeared .
Old 04-03-11, 06:22 PM   #15
ryansv
thanks just had a look and the blue wire was off with the screw next to it so happy thanks a lot
Old 04-03-11, 06:23 PM   #16
xXBADGERXx
There ya go , have a test ride to make sure though
Speedo Over Reading. tonynorman SV Talk, Tuning & Tweaking 12 01-09-10 12:16 AM
Speedo reads erratically. bengrrr SV Talk, Tuning & Tweaking 9 08-06-10 08:07 PM
Speedo reading too fast Suzi SV650 SV Talk, Tuning & Tweaking 0 20-05-10 04:19 PM
Is your speedo reading '0'? Uu Mr.E uU SV Talk, Tuning & Tweaking 14 05-03-10 08:46 AM
speedo over reading steveg SV Talk, Tuning & Tweaking 2 09-09-06 03:09 PM
