#11 |
I would be more likely to think that it is a sticky caliper that is making the master cylinder feel lumpy.If it moves freely when disconnected and the internal rubbers are good look elsewhere
#12 |
As i said the rubber on the cyclinder by the lever is all perished and broken up and it is definately the lever end which is sticky/knotchy but i will inspect the calipers when i do the work
#13 |
I reckon Dicky's correct with this. I done the same as you're planning only to have to completely service the calipers. A perished boot is a perished boot. It's pretty much a dust seal.
If you know how it'd make sense to take off the calipers and check the pistons are moving nicely. P.S. The circlip pliers should be fine. |
#14 |
Question, do all circlips have the same size holes for the tools no matter their size?
#15 |
Question, do all circlips have the same size holes regardless of their size?
#16 |
No. They will be fairly proportional. You couldn't have a mahoosive circlip with tiny little holes nor a tiny circlip with mmahoosive holes. They just wouldn't work.
#17 |
Oh &%*$£, the plier i have just got dnt fit the circlip in the new clip, the ed of the pliers are too big, will have to return and get a smaller pair from Halfords or summit, unless someone has some kicking around i could get by the weekend?
Front master cylinder | sniff | Stuff Wanted | 3 | 28-04-10 09:19 AM |
Front Brake Hoses and Master Cylinder - Curvy | Big Daft Lad | Stuff Wanted | 1 | 13-02-09 12:37 PM |
Pointy or Curvy, 650 or 1000 Naked SV Front Master Cylinder | SoulKiss | Stuff Wanted | 0 | 19-03-08 06:30 PM |
Front master cylinder | taggy | Stuff Wanted | 7 | 31-08-07 06:02 PM |
R1/R6 Front master Cylinder | jonnygman | SV Talk, Tuning & Tweaking | 6 | 29-04-07 01:10 PM |
