#11 |
I think this is the same seller as moto777, these levers were also rated by someone on the previous thread.
Seemed a bit suspect! Why change names and lose all that feedback? But good to hear their stuff is good. Might look out for a set going over at £22.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground" The Stoppy King
#12 |
You don't lose feedback for a name change. I've done it before on my eBay account. Might have done it to make his company easier to find.
#13 |
Probably to get rid of negative feedbacks?
They had a few hundred but then again they had sales of 20,000+
#14 |
#15 |
No fitting instructions included but very simple to do. Brake : un-do bolt and replace.
Clutch, I found it easier to unplug the cut out switch first and then loosen the holder to rotate the lever round a bit on the bars to make removing the cable easier. |
#16 |
Bought a set of these, took about 10 days to arrive so not bad at all, easy to change over (coppergrease the bolts, makes life easier in the future). Went for the black stubby levers with the 'red' adjuster, may as well say it, it is just pink
#17 |
Ordered a set of stubby black with black adjusters to go on my black on black SV.
![]() We'll see how long it takes them to get here!
#18 |
Does the clutch cutout switch still fit on these levers?
#19 |
It fitted straight on with no problems with the ones reviewed here.
#20 |
Thanks. May well invest in a set of these shortly then.
Adj Clutch Brake levers? | edmc | SV Talk, Tuning & Tweaking | 2 | 24-01-11 11:14 PM |
Curvy Carbs, clutch levers and brake levers | 21QUEST | For Sale - SV's and SV related items | 2 | 03-03-10 11:04 AM |
clutch and brake levers in red | Tristec | Stuff Wanted | 8 | 11-07-09 08:57 PM |
2 finger clutch and brake levers | bronze svrider | Stuff Wanted | 2 | 24-07-08 11:49 AM |
Brake/Clutch Levers | Tris | SV Talk, Tuning & Tweaking | 1 | 18-06-07 12:58 PM |
