Old 08-05-11, 12:47 PM   #11
Trixy750
Default Re: Play in my linkages
Ah right, I see what you mean. For that it relies on the washers taking up most of the gap and the frame lugs flexing in slightly to clamp it in place.
By the way don't ever fit that without the washers as missing them has been known to snap the lugs.
Ah....
That is how it is spossed to work. Need some thicker washers then.
Thanks.
Old 08-05-11, 12:50 PM   #12
Does it even have play when torqued up properly? That would snap frame going down that theory. They are normally pretty snug going in, but with some axial play even when tight.
Try putting spacer (bearing inner) and washers in without the linkage, torque it up. I bet there is no play in spacer then.
Old 08-05-11, 01:14 PM   #13
Trixy750
Yep you are right on that... I just went out and tried to turn the washers (should have thought of that earlier ). They are tight so the bearing must be really shot.
Next to improvise a stand so I can get it off. I read that axle stands on reversed footpegs work OK.
I'll wait for the spares to come through tho.
k3+ suspension dog bones/linkages standard height barwel1992 Stuff Wanted 5 26-04-11 06:21 AM
Think you can play the guitar? can you play it like this? PsychoCannon Idle Banter 3 07-10-06 01:57 PM
