Old 10-07-11, 10:19 PM   #11
SV650Racer
Default Re: Who should i get to fix the SV650
Try the airbox pressure sensor
Old 11-07-11, 11:24 PM   #12
ian505050
Pretty sure there is a guy neat Leeds who is handy with the SV but can't remember his username
Old 12-07-11, 08:25 AM   #13
YEAH...he goes by the name of Yorkie_Chris
Old 12-07-11, 04:52 PM   #14
What happens if you disconnect that? It seems logical it could be something like that. Or maybe a coil breaking down under load.
Old 12-07-11, 07:29 PM   #15
lol omg wtf
If the air box pressure sensor is what is described as (intake air position sensor - IAPS) we did test that with a multimeter following the tests shown in the workshop Manual and it seemed fine, we didn't however take the bike for a run with it disconnected, but may be worth disconnecting it and trying again.
We swapped both coils over from my bike and this didn't stop the issue so I think they can be ruled out.
My pal is just about ready to throw the towel in and leave it at a main dealers really gutting to not be able to find the problem though as I got him into bikes and said if he got the same bike as me we could sort any problems out as we can swap parts
Also im guessing a main dealer would charge many hours labour re-checking all the things we have.
All the input so far has been very helpful!
We need to check the fuel jets still, but its starting to look a bit too "technical" for us.
Old 12-07-11, 10:59 PM   #16
Stonesie
An 04 pointy will not have fuel jets, they are fuel injected.
Intake air position sensor could (and I am guessing here) be related to the secondary butterflys in the intakes, they are ECU controled and rely on a sensor to tell the ecu where they are so it can adjust them as it sees fit.
Old 12-07-11, 11:01 PM   #17
Nothing like a challenge eh.
You tried dealer mode and check for codes? Any FI light while problems occur?
Old 12-07-11, 11:48 PM   #18
suzukigt380paul
Originally Posted by lol omg wtf View Post
Freind's SV650 is still not working right, when you gun the bike it bogs down at around 75 mph. Works fine all the way to light speed if you take it easy.
we have exhausted all options using our limited skill's:
Changed:
* Battery
* Spark plugs
* HT Leads And coils
* Fuel tank and pump
* Air filter
* Fit a standard can
* Checked all pipes for leaks and kinks
* Changed ecu
This has not solved the problem, so now i think we need to get someone with a better knowledge of the sv on the case.
I know there’s a few sv guru's on here and just wanted to know if there's anyone around the leeds area (willing to travel to them up to around 50mile).
If they would be willing to take a look at it i would happily give them some beer tokens for there efforts.
many thanks stephen
* its an 04 pointy.
a mate of mine had a similar problem on his cbr600 and it was the throttle valve sensor the thing that on the side of one of the carbs or if fuel injected throttle bodies with a couple of wires comeing out of it
Old 13-07-11, 12:09 AM   #19
might sound a bit daft but have you checked the vacuum spigot nipples on the throttle bodies as one may be cracked or loose?
2000 sv650 stanchion on a 2004 sv650? kaimera SV Talk, Tuning & Tweaking 6 09-06-11 10:06 PM
Red SV650 Seat, Oxford Indicators & SV650 bits. MattSV650 For Sale - SV's and SV related items 2 09-04-11 09:43 AM
Trading sv650 for sv650 sport?? Wycombe Dave Bikes - Talk & Issues 12 24-08-08 10:26 PM
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator ThEGr33k SV Talk, Tuning & Tweaking 0 25-11-07 12:22 AM
will a 2002 sv650 s cylinder head fit my 99 sv650? bugsy46 Bikes - Talk & Issues 2 07-04-07 04:26 PM
