Old 26-07-11, 11:49 PM   #11
Herrmann
Default Re: Another Emulator Thread?
ah, I see, degressive you mean
4cm is 1/3 of travel and this is what I've read a lot of times to be the correct sag including rider
That is only 20mm you have there, air gap (lack of) is stopping suspension from absorbing bumps so it feels harsh.
It's a bit late, so do I understand you right:
Rider sag has to be 20mm ?
With the current setup I'm not complaining about being harsh. It's just fine for normal ride as long as there is no hard braking
Old 27-07-11, 09:12 AM   #12
johnnyrod
johnnyrod's Avatar
YC is right of course. I'd start again with the stock air gap (this is 105mm on a curvy, not sure about yours), set the emu's to their standard settings, and set the front sag to about 25-30mm with rider (ideally about 15mm without rider but this depends on your fork spring weight) As said above, progressives are a pain for this, ideally you want preload-adjuster fork tops because I find with my Progressive brand progressive springs, adding about 1.5 turns of the preload adjuster goes from feeling good solo to being good for 2-up by squashing the softer part of the spring. Backing them off by the same feels very soft. So, adjusting preload with these by only cutting the spacer tube is a bit crude as small adjustments in preload feel a lot different on the road. I think you need to get this right before you worry too mucha bout air gap and emu settings. I found that the emu's don't stiffen the front much, but they do give much better control, so don't expect it to suddenly feel different on the brakes, it won't.
Old 27-07-11, 11:12 AM   #13
Herrmann
air gap currently is around 90mm, so this shouldn't be too far off, as 100mm is recommended for racing
I'll put the "left-overs" from the spacers in, to see if it feels better
Already tried to get adjustable fork caps, haven't found some of a wrecked bike yet
Old 27-07-11, 11:33 AM   #14
Yeah that sag is ok, problem is you have a massively progressive system, progressive springs and tiny air gap, meaning that 20mm of travel you are using is all the normal travel you get. Force of braking takes you into region where air gap AND progressive springs make everything nearly solid.
Old 27-07-11, 01:59 PM   #15
johnnyrod
johnnyrod's Avatar
While you're setting up the sag, you can use pretty much anything as a spacer then just trim your tubes once. I'd go more for 25% of travel not as high as 1/3rd though, but as you've got progressive not linear springs, it'll take some persuasion to get right. You can buy the fork top adjusters from Suzuki, I don't think they're that much, but you need the disc that goes under them between the adjuster and the spacer tube. You also (might) need to cut more off the spacer tube as the caps are effectively taller. As YC says though, you're getting very soft through to very hard in only approx. 80mm of travel and that's the problem.
Old 27-07-11, 03:17 PM   #16
Herrmann
I'm not sure, if there is a misunderstanding here.
Currently my fork is working alright, I just want it to be more progressive at the end, to save some travel when braking hard on bumpy surfaces.
The caps are around 70 Euros including the discs/washers, already checked that. Currently I'm looking for a wrecked bike offer to get a bargain
Old 28-07-11, 07:37 AM   #17
johnnyrod
johnnyrod's Avatar
So either you need to make the progression more even across the stroke of the forks, and/or you need to start from a stiffer setting so the ramp isn't so steep. The first one is a bit more complex, the second one is probably best done by increasing preload to overcome the softer part of the fork springs. I don't think the emulators are the place to look for this though, i reckon it's the springs/air. What do you think YC?
Old 28-07-11, 11:45 AM   #18
IF you are only using half of travel then it is already more than progressive enough
Cheap emulator alternatives yorkie_chris SV Talk, Tuning & Tweaking 35 29-03-12 09:13 PM
Debrix damping emulator questions bigchris SV Talk, Tuning & Tweaking 13 13-07-11 02:08 PM
Matris Emulator/Cartridges Icanopit SV Talk, Tuning & Tweaking 2 24-11-10 07:20 PM
Full SV fork emulator kit Owenski For Sale - SV's and SV related items 12 15-11-10 10:25 AM
Race-Tech Emulator kit r4ce_e3nd For Sale - SV's and SV related items 13 13-05-07 11:38 PM
