Old 17-08-11, 09:12 PM   #11
Default Re: wanrning sticker removal
Originally Posted by Gaz.sv650 View Post
S*** didn't think of that I will go run and get it tattooed to my hand so I will never forget
Just popes round my local painter and he said it will need a complete respray
My sprayer didn't do a full respray, even where one bit was down to the primer.
Get someone else to check it out
Old 18-08-11, 06:39 AM   #12
Gaz.sv650
Gaz.sv650's Avatar
Oh sweet how much did yours cost if you don't minde me asking as I got quoted 170 if I just take the bike to them and 130 if I just take them the tank
Gaz.sv650 is offline   Reply With Quote
Old 18-08-11, 08:18 AM   #13
it does not need a re-spray. try phoning one of those mobile scratch repair people.
Old 18-08-11, 11:11 AM   #14
Badeye
Wow thats nuts, what year SV is it? I have a K3 in blue and recently removed my warning sticker from the tank with careful use of my heat gun and it only left crappy sticky residue behind, sorted that with WD40 and finished off with some T-Cut Scratch remover with nano technology. can't even tell it was there now. Did exactly the same on the warning sticker on the right side of the front fairing too. They now look great.
Good luck bud
Old 18-08-11, 11:54 AM   #15
Gaz.sv650
Gaz.sv650's Avatar
It's a k6 but the tank and blue bits are of a k4 bike as I wanted it blue and it was cheaper just to buy the blue bits but yeah thanks for the help anyone got a number for one of the mobile scratch repair people?
Old 18-08-11, 12:13 PM   #16
have you checked to see if the paint under the sticker has lacquer on it?
if it has it might just be a case of rubbing down with some 1200 wet'n'dry with lots of water then cut using G3.
Old 18-08-11, 12:16 PM   #17
twowheels
if you key in the area and mask the rest of the tank you could use petrol resistant lacquer, ive done this a few times for things just like this. with a bit of cutting compound you could smooth it all down, cost you about 10 quid i should think....maybe worth a go!
Old 18-08-11, 03:08 PM   #18
Gaz.sv650
Gaz.sv650's Avatar
Will this only work if there is some lacqure under where the sticker was as I don't want to key the blue paint do i?
Old 18-08-11, 03:18 PM   #19
twowheels
just a very light sand with a 1200 grit would be my choice, worked OK on my GSXR tank. make sure you clean it properly after a sanding,
Old 18-08-11, 03:54 PM   #20
Can't remember exactly, but no where near what your guy quoted.
He just blew a little paint into the bit where it had gone through to the primer and then laquered over the top.
Think I had the undertray & set infils done at the same time for just over £100
Sticker removal - how? Jack The Kipper SV Talk, Tuning & Tweaking 11 08-09-10 03:54 PM
Sticker removal. kellyjo Bikes - Talk & Issues 12 23-06-09 06:05 PM
Sticker removal (again!) help please El Saxo SV Talk, Tuning & Tweaking 14 29-03-08 10:06 PM
sticker removal maff Bodywork 1 09-05-07 11:06 AM
sticker removal Wiltshire7 SV Talk, Tuning & Tweaking 18 02-12-04 05:59 AM
