Old 14-09-11, 11:39 AM   #11
phil24_7
Default Re: Pointy (K6) Can - Front + Rear Brake levers
Don't worry about it being too loud...Loud cans save lives.
Kates exhaust is VERY stubbied, leaks a little (due to my attempt at stubbying a very battered can) and is VERY loud, and it goes through the MOT every year, and she has never been pulled on it!
Regards
Old 14-09-11, 01:06 PM   #12
Stonesie
I was thinking about £60 for the can + post It's got a little ding near the badge and the strap has marked it but other than that its a quite unique little can, mainly because it was a sod to do because of the internal pipework... I've not seen another one of these stubbied myself.
See the exhaust re-sleeve thread to see more pics and a vid.
http://forums.sv650.org/showthread.php?t=169361
Edit, the lever is in the post, gave it a clean and a spot of red grease in the pivot.
Old 14-09-11, 01:23 PM   #13
Orca
Just saw the vid in your thread........ Way too loud for me. I commute 400 miles a week. I'd be deaf or driven mad after a month. lol
Thanks anyways fella
Old 14-09-11, 01:47 PM   #14
phil24_7
Get some good ear plugs, they'll protect your ears from wind noise too.
Old 14-09-11, 03:25 PM   #15
Orca
Hahahahaa
Old 14-09-11, 03:32 PM   #16
Reeder
I think he was being serious lol. 400 miles with out ear plugs (assuming that is the case) is insane!
Old 14-09-11, 04:04 PM   #17
Orca
I wear earplugs
Old 14-09-11, 04:06 PM   #18
phil24_7
I never used to use them, and often found myself with ringing ears or not being able to hear conversations properly. Now, I never ride without plugs or headphones unless it is in the city centre/popping to shops etc.
The recon that even short periods of time at reasonable speeds causes permanent damage to the fine hairs in your ears. You may not notice it for a very long time, but eventually you will, and it is irreversible.
Tinitus is not fun, take it from me!
Old 14-09-11, 04:06 PM   #19
phil24_7
Ignore my last post then Orca!
Old 14-09-11, 04:07 PM   #20
phil24_7
In which case, get better plugs, then the only people you will annoy, are the cage drivers that you wake up as you pass them! LOL
Both brake levers for pointy Miss_Undaztood Stuff Wanted 6 04-06-10 11:07 PM
Need front and rear brake levers.... LeonKing Stuff Wanted 6 06-02-10 05:58 PM
K1 Curvy Front/Rear Brake Levers SVNutta Stuff Wanted 0 05-02-08 01:03 PM
Rear and front brake levers plowsie Stuff Wanted 1 04-05-07 11:07 AM
Need Front and Rear Brake Levers mike_b Stuff Wanted 7 20-12-06 11:44 PM
