Old 21-11-11, 11:45 AM   #11
AndyBrad
Default Re: People messing with your bike
needs lube!
Old 21-11-11, 11:47 AM   #12
Roberrrrt
Originally Posted by AndyBrad View Post
needs lube!
Really? Simple as that? Never noticed the footpegs rotating before though?!
Old 21-11-11, 11:55 AM   #13
Owenski
As one of the mounting bolts is missing?
Check the mounting bolts for the rear MC, if the lower one is missing/sheered then I could see how that may pivot around the top bolt causing a peg rotating effect.
TBH though I recon you'd spot this instantly on inspectiong, what time you home tonight flower?
Old 21-11-11, 11:56 AM   #14
-Ralph-
I seriously can't see a fellow nice orger such as Matt, tampering with such important parts of your bike Roberrrrrt.
Kill switch, lever adjustment, and the rubber boot (under which is the adjuster for clutch cable tension).
Somebody is yanking his chain!
The brake pedal is just co-incidence, noticed for the first time because he's looking for things wrong with the bike.
Old 21-11-11, 11:59 AM   #15
Owenski
Thats aftermarket I know but its the image I used for the base of the above logic.
Old 21-11-11, 12:06 PM   #16
-Ralph-
Hang on a minute, this is Leeds isn't it? Yep, I take back my assumption, somebody is trying to nick stuff for sure!
Old 21-11-11, 12:06 PM   #17
TamSV
TamSV's Avatar
If the actual footpeg is rotating, the bolt holding it in place must have come loose.
The peg has lugs that locate into the footpeg hanger. Remove the hanger and check that the big bolt that goes into the footpeg is secure. If it's loose, threadlock it.
Old 21-11-11, 01:54 PM   #18
Precisely!
Old 21-11-11, 04:15 PM   #19
Stenno
+1, Sounds like the allen bolt has loosened and the two locating lugs on the foot peg side are out of place. Although this would be evident if the stem the peg pins onto was loose/wobbly.
Old 21-11-11, 06:41 PM   #20
missyburd
Prank or not, it's still a worry. And why jump to the conclusion it's a prank, although it'd be nice to know who did it, at the end of the day, any biker who felt a mischievous urge that day could do the same.
I park my bike just off a busy street often filled with tourists taking pictures etc. The other day I caught a Japanese chap just getting off it and making a move to balance himself precariously on the seat (bearing in mind it sits on a hill, I park it in gear but it's on a slippy bit of pavement and can inch into the wall if jerked about). So I marched out and very firmly told him where to go. That's the limit of folk messing about that I've experienced but it still made my blood boil, you wouldn't pose on the bonnet of a car or climb on its roof for a good photo now would you!?
Messing about with wheels... northwind SV Talk, Tuning & Tweaking 31 15-05-07 07:04 PM
Messing with me head $tevo Idle Banter 3 13-05-07 03:45 PM
Messing about in the garage... Jdubya Photos 8 13-10-06 09:49 PM
Honda messing up!!! John_pal Bikes - Talk & Issues 22 18-08-05 07:07 PM
