Old 23-11-11, 10:20 AM   #11
Geodude
Geodude's Avatar
Default Re: 3D Motorcycle live pics
'Daft question' do i need 3d glasses or the like to see them? as they are blurry to look at
Old 23-11-11, 12:15 PM   #12
Paul the 6th
Paul the 6th's Avatar
do I need these?
Old 23-11-11, 01:20 PM   #13
Brettus
Back again, right, sorry I should have perhaps explained a bit better but I wasn't expecting too many people to be interested.
When you are viewing a picture you have a mode button in the bottom left, you can choose a method to view them in:
  • Anaglyph (red and blue glasses as per above)
  • Crossed (is a method for crossing your eyes to get each eye to see the slightly different picture side by side, here is a guide)
  • 3DVision if like seggons you have a posh Nvidia 3d vision setup for gaming etc then you can use the 3dvision option at the top.
I suspect the other modes are for compatibility with certain 3DTVs but I don't honestly know.
As I say most won't be able to view them either without glasses because of the lack of ability or lack of hardware to help but feel free to have a go.
I've uploaded some more bike show pictures now that I've had another browse through for the ones that I thought looked good in 3d (I may well be wrong though, personal preference has a lot to do with it)
Full Motorcycle Live album here: http://phereo.com/Brettus/album/4eca...5018773000023/
I've also put up a general gallery of some test shots I took with my Fujifilm W3 which you may be interested in Seggons: http://phereo.com/Brettus/album/4ecc...501f62a000096/
One last thing, I've uploaded a short movie clip (167mb) I'd really only bother with it if you have a 3DTV or a 3DVision setup: http://www.fileserve.com/file/SV2R2da it's just a short clip of a couple of guys going around the indoor motocross track.
Old 23-11-11, 04:16 PM   #14
Mr Speirs
Mr Speirs's Avatar
I get seem to get the crossed ones. Could do it easily in the guide but on your photos it won't work. Think they might be too wide.
Old 24-11-11, 02:16 AM   #15
Webber
Some looked very 3d when mode was set to 'wiggle' others just made my head hurt.
Old 24-11-11, 09:51 AM   #16
Brettus
oh yeah, forgot about the wiggle mode. Sorry about the headache, my associate will hand out painkillers at the end of the thread.
Old 24-11-11, 10:31 AM   #17
muzikill
muzikill's Avatar
Tbh colorcode anglyph looks great on a lcd monitor.
Motorcycle live 2011 mister c Photos 10 23-11-11 06:39 AM
Another NEC / Motorcycle Live thread MisterTommyH Idle Banter 0 20-11-11 09:27 PM
NEC Motorcycle Live show Kenzie Idle Banter 14 26-10-11 07:46 PM
Motorcycle Live at the NEC Littlepeahead Soho Massive 6 26-10-11 04:21 PM
Motorcycle LIVE - NEC - 27th Nov to 5th Dec Amanda Bikes - Talk & Issues 23 22-09-10 08:18 PM
