Old 02-12-11, 04:11 PM   #11
SUPERSTARDJ01
Default Re: Muc-Off
I've got the miracle shine and it's good but super resin polish is better.
Old 02-12-11, 04:47 PM   #12
wyrdness
Default Re: Muc-Off
Originally Posted by Roberrrrt View Post
+1 for WD40 - cheap and works
I just blather any metal bits in it, leave it a few minutes, then wash off before using normal car shampoo to finish. Brings off most grime pretty easily
Paraffin is a much cheaper alternative to WD40.
I haven't tried sdoc100, but have just ordered some.
Old 02-12-11, 05:21 PM   #13
Stonesie
Default Re: Muc-Off
They are both polishes so I wouldnt use them too often, they are very slightly abrasive. I have the SRP and it is brilliant but my regular lotion is turtle wax nanotech wax, apparantly it's a hard wax and lasts months but it gets regular coats of the stuff, probably why I think Muc-Off bike spray is brilliant because most of the crap just runs off, any that doesn't is easily persuaded with a soft sponge and more muc off.
Old 03-12-11, 11:12 AM   #14
Badeye
Default Re: Muc-Off
I don't see why ppl think muc-off is so bad, i've used it on all my bikes and get great results all the time, the chain cleaner and chain lube are brilliant. Infact i have just been out today and bought more muc-off products.
Old 03-12-11, 12:55 PM   #15
Jayneflakes
Jayneflakes's Avatar
Default Re: Muc-Off
I tried Muc Off due to a Sales person telling me it was good. I started by cleaning the swing arm and rear wheel. I had recently used Werth chain oil, which is quite sticky and it had splattered on the wheel rim and when it came to washing it off, Muc Off did nothing. I gave it a good go, but it just could not cut through the mess in the same way that the Hope Cleaner did, what it did do was smear the black oily mess around the wheel rim.
I also used Muc Off chain lube last winter and found it thin and useless. It was probably great for the MTB but was less than great on the SV. The only thing from the set that I still use and like is the Helmet Visor cleaner. It cleans up the visor beautifully, so not every thing Muc Off is poor.
I also used Muc Off Teflon oil on the MTB and found it equally good to my favorite Syncros wet lube, however it was considerably more expensive.
Jayne you're a Pussy Magnet
Old 03-12-11, 01:39 PM   #16
Default Re: Muc-Off
fenwicks motorhome cleaner. once diluted it makes same as 10ltr of muk-off for £8 (spot dilution) and its better. the bobby dazzler also works rather well and does what it says on the tin. for normal washing i just add a cppl caps of the motorhome cleaner to the bucket.
i have washed the bike a few times now with the above combo and each time it's gotten easier and the mud and muck just run off now.
its also a great cleaner to use around the house
Old 03-12-11, 02:13 PM   #17
Holdup
Default Re: Muc-Off
I got the 2 for £10 deal at hg on the muc off cleaner, cant fault it, sprayed the whole of my bike in it then washed off using car shampoo as well, eat through all the sprayed off dry lube on my wheel and made my bike shine quite nicely, used to use castrol greentec cleaner as well which was good
Old 03-12-11, 06:14 PM   #18
muzikill
muzikill's Avatar
Default Re: Muc-Off
What do you use for getting tar bits of bike metal? eg. exhaust
Old 03-12-11, 08:40 PM   #19
Stonesie
Default Re: Muc-Off
On the exhaust, bug&tar remover or autosol.
Old 03-12-11, 09:20 PM   #20
-Ralph-
Default Re: Muc-Off
Paraffin is a £1 a litre, Muc-Off is £7 quid a litre. WD40 leaves a shine. It's all you need.
Good camera? good value? pencil shavings Idle Banter 22 04-12-08 01:40 PM
It's good to know there are still good people in this world andyb Idle Banter 14 17-06-08 05:16 PM
is there a good mechanic,by good i mean cheap wigan650s The Madlanders 3 01-09-05 08:53 PM
Good bike, sit, stay......roll over , theres a good girl! 454697819 SV Talk, Tuning & Tweaking 13 16-08-04 09:35 PM
