#11 |
Or just ride the GSXR in the first place and lose the SV if you're making that much change?
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers |
#12 |
#13 |
I know there was a group buy last year for these Debrix valves - I wonder if anyone who missed out last year would be keen on a group buy?
#14 |
Going to have a go at fitting the rear shock on Saturday - weather permitting. Will the standard dog bones be ok for this? The ZX10 shock is 8mm longer than the SV
#15 |
Should be reet.
#16 |
Awesome. Thanks.
Had to Urban Dictionary that first though : http://www.urbandictionary.com/define.php?term=reet ![]() |
#17 |
For wont of starting a new thread... I'm sure that this has been answered many times before but I've been at this for ages now and my brain is giving up
![]() Giving myself a crash course in suspension (getting involved in the debrix GB) and I came across this page on the racetech website (clicky) - great page. So the low speed compression damping is done by the wee hole in the emulator, and high speed compression opens the valve at the pressure determined by the adjustment knob (i.e. the preload on the emulator spring). Rebound (according to the diagram below) is controlled by the rebound holes and, because it only has to deal with the force of the spring (not the varying forces from the road) is less important to adjust (just change the oil weight instead) so the standard hole is used for rebound damping. I've read that you've got to bore out the bottom compression damping holes (makes sense) and close up the rebound hole(s) in the top of the damping rod before installing the emulators... so how does the oil get from the "central bit" (B) to the bottom of the fork (A) on the rebound stroke with no rebound holes? Clearly I've missed something because to me the only way out is past the (closed) lower check valve. Do the SV forks have a slightly different construction to what is drawn below with some other way to bleed B back to A on the rebound stroke? Aaargh! Thanks ![]() ![]() Last edited by 85jas; 02-03-12 at 07:23 PM. |
#18 | |
#19 |
Aah I see... I guess I wrongly assumed that leakage would be negligible! Thanks for saving me brain
K10 tuning: suspension, exhaust, FI questions. | MA10 | SV Talk, Tuning & Tweaking | 3 | 20-08-10 07:38 AM |
sv650/s suspension questions | barwel1992 | Bikes - Talk & Issues | 32 | 29-09-09 12:22 PM |
Suspension fitting questions | Khewett | SV Talk, Tuning & Tweaking | 25 | 18-02-07 06:14 PM |
fork seal and suspension questions. | Warren | SV Talk, Tuning & Tweaking | 6 | 09-05-06 12:00 AM |
SV suspension ... again but...I have questions | Shooter | SV Talk, Tuning & Tweaking | 3 | 31-10-04 04:22 AM |
