Old 01-02-12, 10:57 PM   #11
Red ones
Red ones's Avatar
Default Re: Think I need a Carb synch
...but with the (EFI) SV, you need an OBD tool to turn off the throttle position sensor (TPS) and they're £150+
Surely, if you have the TPS set correctly then then you don't need to switch it off as syncing is carried out at 1300 rpm when the TPS is inactive
Old 02-02-12, 12:57 AM   #12
embee
embee's Avatar
Also on a carbed bike take the choke plungers out and ensure they are clean, the springs are in good nick, and the cables aren't rusty/cruddy and sticky. The choke plungers need only be a fraction off the seats to cause the hot idle to go completely to pot.
The carb balance itself is probably the easiest thing to do.
The other thing is the idle mixture setting. This is a lot more tricky on an SV because it's very awkward (but not impossible) to get to the screws while the engine is running, and it really needs a little experience to do it "by ear". Start by making sure they are set to teh nominal value (can't remember what it is off hand, you turn them in until they "stop", without forcing anything, then back off a certain amount, typically 1 1/2 turns or similar).
Old 02-02-12, 09:26 AM   #13
And they'll be seized
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
Carb Balancer. RobH13 SV Talk, Tuning & Tweaking 3 05-08-09 08:17 AM
Carb Help. Phaelok Bikes - Talk & Issues 9 01-07-09 02:14 PM
pipes going to carb to carb sv650nutter149 SV Talk, Tuning & Tweaking 3 07-09-08 10:16 PM
Carb icing william t. SV Talk, Tuning & Tweaking 10 28-02-07 11:30 PM
