Old 21-02-12, 06:39 AM   #11
Nobbylad
Nobbylad's Avatar
Default Re: Sv650 cam swap - advice needed
You done yours yet?
Not yet mate, got a long list of stuff that needs doing so waiting for the weather to improve then I'm gonna head up to YC's and do the whole lot in one go.
Old 21-02-12, 11:17 AM   #12
hardhat_harry
Ok here is the gen
Carby - Put inj inlet cam into carby inlet. Move Carby inlet cam to exhaust. I got 10bhp gain with BMC filter(dyno'd)
Inj - Keep Inj Inlet cam in inlet. Put Carby inlet into exhaust. Reported as 2bhp gain
Old 21-02-12, 11:43 AM   #13
If you're minitwinning as far as I know you'd have to keep both cams in the stock position.
Absolutely no reason why you couldn't do a straight swap like for like.
Injected might run a touch rich with them though, maybe.
Old 21-02-12, 01:41 PM   #14
sam.nicholson
Hi Chris,
Thanks for this....but I'm still not 100% sure about the exhaust side.
Using Injection Inlet cams in the carby is a given, not sure why I can't use the exhaust cams as well?
If I can use exhaust cams from the injection will it give the same results as using the old carby inlets as exhausts?
I would then like to fit the carby inlet/exhaust in the injection, as long as it runs OK I'll be happy.....I'm not looking for performance as it's just used for commuting.
Sorry to be a pain to everyone...but I want to get it right!!
Thanks
Sam
Old 21-02-12, 03:01 PM   #15
Do the normal pointy cam swap on your curvy, will get you 4bhp or so. Then you will be able to use what you've got left on the pointy, yeah losing a bit of power but who cares to pootle to work.
There are other parts you can swap too to gain a bit
Sv650 cam swap - advice needed sam.nicholson Mini-Twins 3 21-02-12 07:53 PM
sv650 engine swap k6 to k8 Pix SV Talk, Tuning & Tweaking 1 16-05-10 07:49 AM
sv650 engine swap fromthestreet SV Talk, Tuning & Tweaking 17 20-08-08 05:06 PM
Engine swap advice sixstring SV Talk, Tuning & Tweaking 7 18-01-08 09:44 PM
F3 wheel swap on a SV650 - K4 JanGoris SV Talk, Tuning & Tweaking 12 18-03-06 07:27 PM
