Old 15-03-12, 08:43 PM   #11
Runako
Default Re: Pointy speedo random numbers?
Does it do when the bike is turned on but not running?
??? As in battery on or engine on? Doesn't matter, still 0.
Old 15-03-12, 08:57 PM   #12
Bike switched on but engine not running, when engine running but bike stationary, or only when moving?
Or if more than one then which of those?
Old 15-03-12, 09:05 PM   #13
Runako
Are you taking the ****?
Old 15-03-12, 10:03 PM   #14
Answers to the above may have helped with the identification of the problem. My first post was quite clear but the question seems beyond you, the subsequent ones made it plainer still but you seem unwilling to answer.
It'll have be someone else's help for you from now on. Suit yourself.
Old 15-03-12, 10:07 PM   #15
Runako
Look mate, thanks for trying if you were being genuine, but my posts are too long as it is. How many times do i have to write '0'? My 1st post says "started at 0 and after 30 miles went crazy". Does that not answer your question? Anyway, apologies if i misunderstood something here and thanks for trying. (New thread posted)
Old 16-03-12, 08:14 AM   #16
Originally Posted by Runako View Post
I'll tag my question to this thread as its similar. My k9 speedo stopped working yesterday. Read 0 for a while but then starts going crazy like a lie detector test.
Only recent change was replacing the shovel with a tidy, so disconnecting/reconnecting wiring (I assume correctly), except for what looks like a ground earth wire which I neglected to put back underneath a nut on the subframe.
Other instruments on dash and lights are working fine but also discovered my heated grips won't turn on. I suspect the two are connected but there's no visual damage and I've made no changes to wiring up front.
Any suggestions?
That ground wire was probably your grips -ve.
Same suggestions as at start of this thread, you checked them?
Old 16-03-12, 08:48 AM   #17
kiggles
its probably a shattered rotor. its what happened to my k3. sometimes will show right speed. then would just start jumping to random numbers 19,180,34,85,112, etc.... until eventually over time it will remain at 0. if it is not speedo rotor then check wiring.
calm down
Old 16-03-12, 08:54 AM   #18
kiggles
image of pretty much what mine looked like before and after fixing
http://media.photobucket.com/image/s...3/SV108258.jpg
here is a thread for doing job
http://forums.sv650.org/showthread.php?t=109242
Old 17-03-12, 09:26 AM   #19
Runako
Yep ground wire was grip problem. Thanks YC. Will check Rotor for speedo. Cheers.
Old 17-03-12, 08:15 PM   #20
Badeye
Runako, I hope you have more luck than me, Mine was doing the same, i checked the rotor and it was like new. God knows what the problem is, anyway its been behaving itself for the last couple of days.
random numbers generator or not? Spider SV Talk, Tuning & Tweaking 2 18-09-09 10:31 AM
My Speedo, aka The Random Number Generator? dode74 SV Talk, Tuning & Tweaking 7 29-07-09 07:49 PM
Random pointy bits - black plastics, tail tidy and more etuna Stuff Wanted 7 03-06-08 06:02 PM
Random Post about Random Stuff tricky Idle Banter 14 13-02-06 08:03 PM
