Old 25-02-12, 05:12 PM   #11
Default Re: England vs Wales
Am I alone in thinking that was a harsh decision?
Old 25-02-12, 05:15 PM   #12
Yep, was harsh IMO.
Old 25-02-12, 05:44 PM   #13
Well Wales were lucky IMO.
Old 25-02-12, 05:44 PM   #14
jonny.boyd
jonny.boyd's Avatar
Looked like it was down to me.. hard call though
jonny.boyd is offline   Reply With Quote
Old 25-02-12, 05:48 PM   #15
I thought it was down too tbh but understand why it wasn't given.
Old 25-02-12, 05:50 PM   #16
MisterTommyH
MisterTommyH's Avatar
The 'inexperianced' England team were better. Went down hill from when we changed scrum half and fly half.
It wasn't a harsh decision to sin-bin. England had a clear line to try and he tackled a man without the ball - he knew he would get binned and in the end it was worth it. Unforgivable to England not to take advantage of the extra man.
Thought a couple of refing decisions lost it for England. The knock-on that got Wales all the way up the field (and the ref was heard on mic later saying "I thought it came off his head").
Also that try at the end. IMO the ball was down behind the line when you compare the two angles (one from behind showed it grounded, but is unclear when it's over the line, the one from the front then shows when it is grounded it's behind the line - although you can't see the actual grounding because there is a leg in the way). I can understand why it wasn't given, although IMO it was questionable about whether it was under control when it was grounded.
MisterTommyH is offline   Reply With Quote
Old 25-02-12, 05:50 PM   #17
Odd decision at the end, the TV shows it actually goes down at least once and possibly in the fumbling, twice. Enjoyed it anyway.
Old 26-02-12, 12:32 AM   #18
Venom
The angle from the touchline shows Strettle tackled and landing on the ball before the line. He's then rolled over onto his back, his arm underneath the ball so the ball is not in contact with the ground to be a valid try. George North then rolls the ball back where it does ground outside the in-goal area. That is what it appears to me so I can see why the TMO ruled it to be inconclusive .
Old 26-02-12, 03:39 AM   #19
BanannaMan
BanannaMan's Avatar
Say what you will.
In the end.....All that matters is the score.
Cymru Am Byth !!!
...Bill
Old 26-02-12, 09:22 AM   #20
454697819
It was a try and a knock on.... Bad Reffing and we will sort it next yr
My England and Wales trip! sam anon Photos 14 26-09-10 11:59 AM
Tour of England and Wales (well,some of it anyway!) sam anon EuroTour 6 04-08-10 09:36 PM
Only in England... Paul the 6th Idle Banter 10 09-05-09 08:47 PM
Touring England and Wales zunkus Photos 14 12-03-08 09:27 AM
England 19 - Wales 26 Welsh_Wizard Idle Banter 8 04-02-08 09:58 AM
