Old 18-04-12, 08:34 AM   #11
Default Re: Potential pointy Adjuster Plates Group Buy
heheee, curvy owner liking pointy bits.. must look good
Old 18-04-12, 08:39 AM   #12
Ha Ha Ha....... your chain needs a good clean
Good work Bib, that's a neat solution for the Scott Oiler pipework
Old 18-04-12, 08:53 AM   #13
Nobbylad
Nobbylad's Avatar
Looks good, I'll deffo take a set.
Old 18-04-12, 09:04 AM   #14
MJC-DEV
MJC-DEV's Avatar
Very nice, will deff have a set. Not having a downstand would suit me better as well.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 18-04-12, 09:12 AM   #15
muzikill
muzikill's Avatar
Aye, count me in for a set.
Bibio. start doing these on ebay btw.
Old 18-04-12, 09:16 AM   #16
garynortheast
garynortheast's Avatar
Another curvy owner liking that too Bibio. Is there any reason why, with a spacer behind it, that arrangement wouldn't fit a curvy swingarm?
Old 18-04-12, 10:21 AM   #17
The Guru
1..joshwalker094....
2..DarrenSV650S.....
3..Epic Monkey......
4..MJC-DEV..........
5..Nobbylad.........
6..muzikill.........
7..The Guru.........Non-Scottoiler
8..The Guru.........Non-Scottoiler
9..
2 sets for me (one for me and one for my brother)
Oh and I want my sets hand delivered on one of the monthly runs
Old 18-04-12, 10:48 AM   #18
Nobbylad
Nobbylad's Avatar
I'd be happy to have mine delivered to Joshwalker (or his to me) to save on postage...same applies to anyone else in the NW of England.
Old 18-04-12, 11:00 AM   #19
Fluffer
Fluffer's Avatar
9.. fluffer
10.
Go on then - looks shiney therefore must be good
Sent from my GT-I9100 using Tapatalk
Fluffer is offline   Reply With Quote
Old 18-04-12, 11:11 AM   #20
Kilted Ginger
Well done lance, count me in. If they are done in time for the AR i'm happy to transport any down there for folks.
9.. fluffer
10.Kilted Ginger
potential pointy ecu restrictor kit bargain haydensv650 Stuff Wanted 0 18-08-11 07:40 PM
Replacement chain adjuster plates? SV400Rob SV Talk, Tuning & Tweaking 13 02-02-11 09:30 PM
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Stainless adjuster plates.....................bling svrash SV Talk, Tuning & Tweaking 19 23-04-06 07:22 PM
