Old 31-12-12, 02:47 PM   #11
savage86
Default Re: Pointy Stem Size?
Be carefull unless you have a hollow yoke nut might not fit. I'm trying to get my self a gps/phone holder rig going got some bits coming in the post will let you know how it goes.
Old 31-12-12, 03:59 PM   #12
burger. that's what i get for being slow.
Old 31-12-12, 04:12 PM   #13
Epic Monkey
I found the best option when I got a mount for my old pointy was the stem from ram mounts - you cut the rubber plugger thingy to exactly the right size. My pointy fell just in between two sizes. One was too big, The other too small.
I also had to buy a gsxr 1000 yoke nut from a dealer. The nut alone was £27!!!! Crazy.
Old 31-12-12, 04:36 PM   #14
i'm making one up that fits between the mirror mounts and sits inside the screen above the clocks. it will be a bar that has a plate to take RAM accessory's, looking at end of February though. at the moment i just stick a sucker to the rev counter
Old 31-12-12, 06:10 PM   #15
SIII
SIII's Avatar
Talking Re: Pointy Stem Size?
Just ordered my phone holder / sat nav, same one for Samsung S2.
Here
I am going to be making a bracket up to use the pinch bolt on the top yoke at the left hand side. Think i will use a threaded bar and nut to pinch yoke and then be able to bolt / unbolt bracket when not required. Will see once made up.
I feel this would be the best position for me. High enough to see over a tank bag and low enough to still see the clocks. So the screen is in the same position as the ignition key but on the left.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 31-12-12, 07:16 PM   #16
Skybaba
O.K will definitely do. I was almost ordering the stuff online, but still don't know the size.
Got a dumb question.......I'm looking in the Haynes Manual and I'm not totally clear. Is the stem nut actually holding anything in place?
Old 31-12-12, 08:28 PM   #17
yes your top yoke
Old 31-12-12, 08:30 PM   #18
savage86
Holds the triple tree/top yoke in place.
Old 31-12-12, 08:48 PM   #19
Skybaba
yes your top yoke
Thanks Guys!! So is the RAM going to hold the yoke in place?
Old 01-01-13, 01:38 AM   #20
savage86
No not really your yoke nut will prob look like this but without the hole.
You'll need a yoke nut with the hole in it so that the RAM can slot through it and bolt on if i'm not mistaken.
They can be bought on ebay for not to much monies.
Steering stem top nut size? MisterTommyH SV Talk, Tuning & Tweaking 17 18-07-11 09:18 PM
Size Of Curvy Stem Nut? Aquila SV Talk, Tuning & Tweaking 14 08-02-11 03:04 PM
what size tank bolts do i need k3 pointy barwel1992 SV Talk, Tuning & Tweaking 11 21-03-10 01:45 AM
Whats the ehaust stud size for a pointy? DanF SV Talk, Tuning & Tweaking 3 15-05-07 12:39 PM
Quick one: What size tyres do I need for my pointy? thor SV Talk, Tuning & Tweaking 4 05-06-06 07:51 PM
