Old 21-05-12, 01:19 PM   #11
NTECUK
NTECUK's Avatar
Default Re: Puncture repairs
I can see it. But would I hope over the fence and nick it .......
Old 21-05-12, 01:21 PM   #12
SoulKiss
SoulKiss's Avatar
Stolen wood burns better
Old 21-05-12, 01:27 PM   #13
Owenski
Admitantly it makes it more impressive if you post 2 links but it only works if you link two differnt ones
Old 21-05-12, 01:31 PM   #14
NTECUK
NTECUK's Avatar
Will wait and see if Dave comes up trumps.
How much in weight.
Old 21-05-12, 01:35 PM   #15
SoulKiss
SoulKiss's Avatar
Don't know what you are talking about
Old 21-05-12, 01:42 PM   #16
jambo
jambo's Avatar
Originally Posted by Bordtea View Post
But how can it go wrong? I've got a puncture that's not ridiculous, goes down maybe 10psi in 24 hours so it's not a potential blowout. If the puncture repair failed, the tyre isn't going to blow on me at 70mph, it's just going to carry back on as normal, deflating at 10psi per 24 hours surely?
I stand to be corrected though.
I'm afraid it's not quite that simple.
The tyre is removed, and the offending article removed, leaving a small hole. This small hole is probably too small to accept the bung that will fix it, and anyway, the sides may be jagged. Often the tyre shop will drill the hole out to the correct size and then fit a patch / bung from the inside, and cut it to length. This is completely safe and standard, but the hole that now exists is not the same as the one at the start, so if it were to fail the air loss could be greater than that of the original puncture.
Again, this spectacularly unlikely, and I've happily done thousands of miles and track days on professionally repaired tyres using the above method without any issue at all.
Jambo
Old 21-05-12, 02:09 PM   #17
Owenski
ha, I predicted your move so quoted your orginal... I learnt that from you lol
Old 21-05-12, 02:34 PM   #18
SoulKiss
SoulKiss's Avatar
Now go build your own Lightsabre
You will note that I didn't edit my original faux-pas, just the version I quoted
Old 21-05-12, 02:47 PM   #19
NTECUK
NTECUK's Avatar
You can allways fix it your self.
Then if it goes t###s up you can haunt yourself
Old 21-05-12, 03:16 PM   #20
StewartR
Whad'ya know - In they same town with the same problem and ended up at the same place. My mate's DL, not my SV thankfully. I ended up doing the do though as I have a car and he just has a unicycle
'Ride In' in Reading will do repairs as well but I couldn't get there before they sloped off for their early Monday close so it's being dropped at Nick's tonight and I'll scoop it up on my way home tomorrow.
Puncture Repairs near Cannock / Burntwood? MisterTommyH Bikes - Talk & Issues 9 14-04-12 11:13 PM
Does anyone here do laptop repairs? Lozzo Idle Banter 20 30-04-08 11:33 AM
puncture repairs (leaking) tomjones2 Bikes - Talk & Issues 8 13-03-07 05:48 PM
End can repairs alexb Bikes - Talk & Issues 8 08-05-06 08:19 PM
Puncture repairs near Bluewater? Jdubya SELKENT 3 09-07-05 05:34 PM
