#11 | |
Don't get me wrong. I smoothly let out the clutch most of the time, but I'm prone to errors when pleasure riding, and preoccupied with the approaching corner.
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#12 |
[QUOTE=AZZ3R;2717230] Blipping your throttle aswell as going down the box smoothen's the gear changes, doesn't stop any harshness. If anything it makes it worse because your upping the revs & lowering the gear.
QUOTE] Not sure about that one. See this thread http://forums.sv650.org/showthread.p...=blip+throttle Explains what blipping the throttle achieves ![]() Last edited by dkid; 25-05-12 at 05:40 PM. |
#13 | |
#14 | |
This is based on car driving (I don't have enough experience on a bike to comment fully) and I was taught this by driving instructor and advanced driving intructors. However if you need a lower gear for corner or need to scrub off 5-10 mph when travelling 60+ then knocking down a gear would be fine. If coming to a stop brakes imo are a must. Cheers Rich Sent from my GT-I9100 using Tapatalk 2 |
#15 | |
let the revs drop first to an acceptable level (its a twin it will drop fast when you shut the go juice off) say 4-5k then blip throttle to 6-7k pull clutch in change down a gear while still at 6-7k then let clutch out. by the time you let the clutch out you will be doing 4-5k again but because you are now in a lower gear you will be going slower. next gear then reduce by 1k revs so on and so on till you come to a stop with the brakes. if it feels jerky when your doing this then your doing it wrong, well that is unless your ragging the titz out of the bike but doing this will just ware your consumables quicker. smoothness is the name of the game. for instance cracking the throttle open out of corners will eat chains, sprockets and tyres, so instead roll the throttle on. be smooth...... |
#16 |
Ok I know I'm a girl and therefore probably don't ride as "hard" as you lads but humour me here
![]() I also blip the throttle on downshifting, I very rarely use the front brake unless making good progress in the twisties. I was taught that good use of engine braking indicates better forward planning in comparison to slamming on the brakes all the time. This thread is the first I quickly learned to blip, and apart from loving the sound it's the riding style I'm accustomed to. Having had to ride all winter and on various crappy road surfaces (eee it's grim oop norf ![]() ![]() At the end of the day you ride how you ride and feel most comfortable with, it's not like engine braking is the only thing to contribute to excessive engine wear. You're not going to know when your engine finally gives up the ghost exactly what factors contributed so just ride it ![]() |
#17 | |
Getting rid of the fear to use your front brakes would be a useful thing, when the cr&p really hits the fan and you need to slow down good and proper (not always something that you'll be planning for) then that front brake might well save your bacon. It will perform far better than any other method of slowing the bike down in a hurry. Plus, brakes are brakes, that's what they're there for. |
#18 |
front brake is the primary way of slowing the bike down. As you say, ride however you're comfortable but don't negate it all together. Smooth application shouldn't result in catastrophy in most cases. Grabbing a handful might... ![]() |
#19 |
If you're dropping the clutch on downshifts without matching engine speed to road speed, yes, you'll probably wear the tyre as you're forcing the tyre to go at a different speed to the road surface travelling under it.. With the SV it's quite easy to get the back to slide doing this....
If you want tyres to last longer, ride smoother, BUT having quickly read the other thread you started about tread depth, I don't think you state exactly which tyre you have. If you've got a sportier tyre, the middle bit won't last that many miles.... If you've worn out a sport touring tyre in a couple of thousand miles, then your riding style is probably a bit extreme.... |
#20 | |
![]() Like anything in riding, it is a compromise... the purpose of a shift is to get into the right gear for "whatever", do you do it the "fastest" way and pagger down 5 gears at once while braking at absolute maximum rate? Do you blip and shift so that the tyre is "loose" all the way in to the corner? If you are smooth (this is KEY!) then downshifting to keep the revs around 6k will probably not cause massive tyre wear. Using 9k engine braking all the time would probably see a difference. However if you don't know how to change gear properly and get a lurch when you let the clutch out, then this will tear tyres...
Clutchless Shifting | Girth | Bikes - Talk & Issues | 34 | 16-05-09 07:50 AM |
smooth shifting | crankcase | SV Talk, Tuning & Tweaking | 3 | 26-04-08 03:46 PM |
Rough Shifting?? | paulc227 | SV Talk, Tuning & Tweaking | 3 | 29-07-07 10:44 PM |
Shifting Problems | Mavfan | Bikes - Talk & Issues | 8 | 13-04-07 02:17 PM |
shifting gears?? | ryrides | SV Talk, Tuning & Tweaking | 8 | 29-12-05 12:02 AM |
