Old 19-06-12, 09:54 PM   #11
Default Re: Frame slider broke on crashing - common?
The ones you had didn't mount on a rod right through the frame, this was your issue, and why they snapped. Motosliders from the US, are different. The ones this fella sells are motosliders, and you can only buy them from US suppliers, him being one of them.
IMO, I wouldn't buy anything other than either these or R&G, and even then R&G I have my doubts over, as I have them on one of my other bikes, and they don't do the job they are supposed to do. I have had to modify them to fit, even though they are sold as specific to that bike.
Old 20-06-12, 08:13 AM   #12
flymo
flymo's Avatar
Originally Posted by Mikey10 View Post
crash bungs are'nt for sliding down the road. they are for droping the bike when man handling it hence why you'll never see any track bikes with them becuase there like anchors when a bike slides down the road they just dig and flip the bike causing more damge and possible damage to the chassis
bollox
Old 20-06-12, 12:18 PM   #13
agy
Hmmm don't now what to do now. Sliders or no sliders....? If they cause the bike to flip...? Don't know whether to have them or not??
I'm not sure I understand the difference between those US ones. These ones I had were mounted on a very long screw. The screw and part of the slider stayed in. Just half of it broke of.
Old 20-06-12, 12:20 PM   #14
agy
these are the ones you need if your bike has lowers.
http://www.ebay.co.uk/itm/SV650-No-C...item56463b90f3
or these if your bike doesn't
http://www.ebay.co.uk/itm/SV650-SV10...item56463b8d40
I have the curvy equivalent, and they have been tested on that tarmac surf I told you about
Ah I think I see what you mean, it's one rod for both rather than two separately mounted
Old 20-06-12, 12:23 PM   #15
flymo
flymo's Avatar
They are a very useful addition, simply because when you're bike goes over they take the hit instead of your frame and engine casings, bodywork etc. They do occasionally break (thats part of the territory of being a crash bung), some are better quality than others.
Will they always work 100% and prevent any further damage? No. In many many cases they will prevent the damage from being far worse. If a bike is going to flip, it will flip, regardless of whether or not you have these fitted. Very rarely will crash bungs make things worse.
I've used the R&G to good effect, also the DHM Motrax ones survived many a race crash for me. The Motosliders ones are fairly sturdy and also worth the money.
Old 20-06-12, 01:41 PM   #16
agy
So the conclusion is, I should have some.
So the motosliders - is that a specific brand name?
Old 20-06-12, 01:43 PM   #17
agy
These are the exact ones i bought:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_2322wt_1180
Old 20-06-12, 01:58 PM   #18
flymo
flymo's Avatar
Originally Posted by agy View Post
So these are better than nothing, but their weakness is in the length of the bolts and the fact that they are separate bolts. I had DHM bungs of a similar design fitted to my race bike, they worked well a number of times. Other times the bolts bent.
It could be argued that the Motosliders type are a better stronger design, but to be honest it really depends on the type of crash they are involved in. If you've already bought these then you could go ahead and use them, no point in wasting £30 or so.
Nearly losing it, (crashing). cluffy SV Talk, Tuning & Tweaking 12 16-03-11 09:50 PM
Various curvy bits - Brand new brake pedal and lever, frame slider, standard zorst and others dafne For Sale - SV's and SV related items 16 12-11-10 11:58 PM
SV650s 2002 frame, rear sub frame with loom etc for sale mattglavin For Sale - SV's and SV related items 1 09-07-09 04:29 PM
Front engine bolt removal/ frame slider fitting Dave20046 SV Talk, Tuning & Tweaking 21 21-09-08 11:44 AM
Frame Slider Bolts rick0361 SV Talk, Tuning & Tweaking 0 26-03-08 10:26 PM
