#11 |
Im thinking the best explanation might be that standing on the pegs allows the weight of the rider to adjust the centre of gravity(by adjusting their body mass) quicker to take into account changing conditions.
#12 | |
![]() SK and I were just being typically facetious and yanking your chain. |
#13 |
To be honest I'm struggling to model the physics of it in my head because the rider must operate as a semi independent mass. I'm thinking that although the centre of gravity is slightly higher it can be moved further over the wheels when the bike leans/turns by the riders shift in position (and weighting the outside peg)making it seem like the COG is lower?
#14 | |
![]() And there was me going to get all into complicated arguments involving pendulums and other cobbled together because it sounded vaguely plausible even if unplausible theories until you poiled it Ralph ![]()
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#15 |
When upright, transferring weight from the seat to the pegs lowers the CoG. If leant over this alters as forces are not straight up and down. If you were upside down the CoF would be on nearer your head.
Back to the original post, yes, often stand on the pegs, especially trackdays or off roading. Can save a highside purely as you aren't wiggling your backside from side to side if you have the pegs weighted and slightly off the seat.
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660 |
#16 | |
When standing up off road you can put your weight over the bars for hill climbs, or over the tail for descents, and as you rightly said it centralises your weight between front forks and rear shock, giving the rear shock an easier time and allowing the front forks to do more of the work. You can also weight your pegs to help with slow speed turns and technical stuff. Standing up you are still on the pegs, so the bike and rider still have a single (higher) COG as an assembly, but what you are effectively doing is making that COG the sum of two separate bits of mass (weight is a combination of mass and gravity) within the one assembly, one lower down and pretty much fixed (the bike) and one higher up and adjustable (you), so you can move your overall COG around as you need to. The reason you feel like it has a lower COG, is that you can move the weight of the bike independently of your own weight, but a mass can only have one COG and so long as your and the bike are still attached to each other, that COG is for the whole assembly, and it's higher than it would be if you were sitting down. Imagine drilling a hole in the handles of two hammers, and fixing a pivot between those two hammer handles. You have one assembly, with two bits of mass, and one adjustable COG. Last edited by -Ralph-; 20-06-12 at 11:03 AM. |
#17 |
Simples,
Bike with rider in saddle makes 1 homogeneous mass. Bike with ride off of saddle makes 1 homogeneous mass and 1 human counter balance. The thing which makes NO SENSE is when you see enduro events and riders have thier feet off the pegs but their bums on the seats Robbbeerrrrtt will no doubt remember my bambozled shouting of "feet on the pegs feet on the pegs" when we went to the nationals event at Tong last year. |
#18 |
#19 |
On a speedway style corner it makes loads of sense.
#20 |
That depends upon how heavy you are in comparison to the bike. If your 18 stone in your riding gear, on an 18 stone enduro bike, then dropping where the weight rests, isn't going to compensate for raising your fat rrssss higher in the air.
If a man is standing...? | Bri w | Idle Banter | 16 | 15-03-11 06:01 PM |
Free standing Punch bag! | Tom_the_great | Idle Banter | 4 | 07-09-10 11:14 AM |
fizz: out standing in his field.. | Quiff Wichard | Photos | 0 | 28-08-10 08:28 PM |
Standing water | Kilted Ginger | Idle Banter | 15 | 21-12-08 06:03 PM |
Standing Start | Daimo | SV Talk, Tuning & Tweaking | 8 | 12-04-06 06:00 PM |
