#11 |
If it is saying primary master none then the bios is not seeing the hard drive. Have a look for an option that says 'Load bios defaults' hit yes. then select save and exit. It should reboot. Hopefully it will find the hard drive. If not then maybe the hard drive has failed. There is a section in the bios to manually setup a hard drive but you shouldn't have to go near that, it should all be set to auto.
Chris
10 GSX650F 95 BMW Funduro 89 FZR250R (x2) 92 RG80 (x2!) 89 AR125 - 89 RG125 75 CB200 |
#12 |
Hindle, cheers for that. I've got one last option to try and then i may be bringing the laptop to you
![]() Chris - cheers; i've tried that - in the bios setup menu it was F9 if i remember correctly. the manual setup hard drive is set to auto and iirc it cant be changed |
Any VBulletin Guru's about? | JamesMio | Idle Banter | 4 | 05-01-12 10:41 PM |
What computer operating system are you using? | rob13 | Idle Banter | 47 | 22-10-09 12:03 PM |
Low resource Operating System for Gaming | DarrenSV650S | Idle Banter | 19 | 07-07-09 08:59 PM |
Request for assistance ~ Arrow Full System 2Gen | VARIABLE9 | SV Talk, Tuning & Tweaking | 14 | 24-03-08 05:50 PM |
OK Windoze guru's (Excel Question) | timwilky | Idle Banter | 7 | 23-10-07 11:57 AM |
