Old 25-10-12, 11:45 AM   #11
Default Re: Oil change confusion
Don't bother worrying about ml's. Either the spec is wrong or the marks on the oil bottles are wrong but they always seem to take a bit more.
Just make sure oil goes to F mark on sight glass and there is no problem.
As YC
I'm sure is about 2.6l (if you get OCD about it) on a oil and filter change. The filter holds quite a bit of oil. If you do a change, steadily pour 2l into the motor, give it a few minutes to flow and settle, then slowly keep topping it up to full.
Give the engine a quick crank once its the the F mark, recheck, then run it for 10 secs at idle, kill it, let it settle and recheck. Then run it for 10 minutes on the stand, let it cool, recheck and ride
Old 25-10-12, 12:11 PM   #12
philbond07
Yes well that's how it should be done, did it like that past 9 years. But not this time. I am quite sure though I put 2.5 liters in there initially, according to indicators on motul 5100 10w40 4liter-cans. Could it be that the hiflofiltro contains like 300ml more oil than a genuine suzi filter?
How to reduce mic volume (not electronically)? Fallout Idle Banter 22 03-08-12 05:42 PM
Working out cubic volume hongman Idle Banter 26 05-01-11 10:50 PM
Help - volume of a structure Ed Bikes - Talk & Issues 14 13-04-06 09:48 PM
And the horn lost volume?! localhost SV Talk, Tuning & Tweaking 10 31-03-06 02:18 AM
Help - volume of a structure jimmy4237 Idle Banter 14 07-01-70 01:49 AM
