#11 |
BTW Dabteacake, many modern caps are two way valves, they let excess pressure out and atmospheric pressure in.
#12 | |
#13 |
Indeed, but that wasn't a curvy, and I've never had a curvy, so it's just a theory. Still doesn't explain everything in the OP. If the hoses are indeed under constant pressure and leaking from the jubilee clips as the OP suggests (that's just the conclusion he's reached, it doesn't mean it's right) then that pressure is getting trapped somewhere it shouldn't and isn't finding it's way to the expansion bottle. I've seen more than enough threads where the conclusion doesn't correlate to the symptoms, to know to not always take the info in the OP as gospel.
#14 |
it doesn't work exactly as ralph described.
the cap has a release valve which stands in the way between the cooling system and expansion bottle. so if the said valve was stuck, system would remain pressurised, possibly causing the hoses to weep at the clamps. i just don't see how the cap valve could fail to a permainently closed state. it's just a plug on a spring, easy enough to compress using fingers. |
#15 | |||
Have you had it off and looked at it? I think it should be opening at about 1 bar of pressure. A new one is about 25 quid. Last edited by -Ralph-; 13-09-12 at 09:50 AM. |
#16 |
just to wrap up the thread:
did a thorough check of the plumbing the other day and found the cause of the problem: the thin hose leading to the expansion tank was blocked with white crap. cleaned that, flushed expansion tank with a few litres of water, tightened hose clamps and all should be ok now. so yeah, change your coolant regularly and don't use tap water (not that i did, but someone before might have). |
Random Coolant overflow - Curvy. | victor_meldrew | SV Talk, Tuning & Tweaking | 11 | 01-04-12 08:14 PM |
Coolant | Gary C | SV Talk, Tuning & Tweaking | 3 | 14-08-09 11:29 AM |
Windows seems to have developed a sense of humour | DarrenSV650S | Idle Banter | 14 | 31-10-08 12:42 PM |
Curvy coolant | AndyBrad | SV Talk, Tuning & Tweaking | 8 | 19-08-08 03:19 PM |
Noisy bike, coolant low? | TheStudent | SV Talk, Tuning & Tweaking | 5 | 09-02-08 09:31 PM |
