Old 25-09-12, 08:56 AM   #11
Default Re: LED Motorcycle headlights?
aye thats the one
Old 25-09-12, 09:01 AM   #12
littleoldman2
littleoldman2's Avatar
What do you mean the aim off battery? It would really be conducive to conversation if you'd type more clearly in something resembling English.
Although to take a flying guess at what you mean; the battery will be in a separate container mounted on the waistbelt connected by a power cord. The container will have 6x 18650 lithium cells in parallel which should give 5.5+ hours of runtime at full power.
Andrew does speak in something resembling English if only remotely.
On a serious note Many of the after market LED light are above 1200cd ( the ridiculously high limit for DRLs) and many of the retailers have no idea what the light output is or the shape of the beam. In the near future this may become part of the MOT.
Old 25-09-12, 09:03 AM   #13
Yeah that's why I'd recommend having them as something like driving lights on a separate switch and not as general headlights.
Old 25-09-12, 10:19 AM   #14
NTECUK
NTECUK's Avatar
You could glue this to your lid lol
http://mobile.maplin.co.uk/module.aspx?moduleno=225316
Old 25-09-12, 10:22 AM   #15
NTECUK
NTECUK's Avatar
I want a cree like on my head torch I can fit in my dip beam lamps.
My lenzer cree is so bright every one at work goes mental if I look up when its on.
Old 25-09-12, 10:32 AM   #16
They don't work well with reflectors that are designed for incandescants sadly.
Old 25-09-12, 11:06 AM   #17
NTECUK
NTECUK's Avatar
The one in my headlamp has quite a small lens.It would need the cut off sorting out as its a circuler beam pattern .I think it could be made to fit in the H7 appature.The front lens is only clear so the reflector shouldn't interfere.
Old 25-09-12, 11:21 AM   #18
That would be cool, but I wouldn't think a head torch would usually produce near enough light to compete with 55W of halogen.
Go somewhere dark and get some beamshots, you'll have to find a way to set the exposure of your camera to get a fair comparison.
Old 25-09-12, 11:29 AM   #19
Be interested to see the comparison.
I'm looking at this for a secondarys or a retro-fit into the Curvy running light
Old 25-09-12, 11:53 AM   #20
Dipper
Dipper's Avatar
These http://dx.com/p/t6-smooth-crown-wate...t-82507?item=6 could be used as a starting point for some very bright driving lamps. I've been using them on my pushbike for a couple of years now, a pair will give at least 100m forward vision, they cant be used in traffic as they are at full power and would need mods to the reflector and lens to be safe on a motorbike. These http://www.aliexpress.com/item/2-in-...617640855.html are now available for about £15 again XML-T6 LED I'll be giving some a go this winter to see if they're any good.
Dipper is offline   Reply With Quote
Headlights, only one as dip? hkhksh SV Talk, Tuning & Tweaking 4 09-03-10 09:11 AM
Headlights ejtrent SV Talk, Tuning & Tweaking 1 09-12-07 12:54 PM
Headlights Ed Bikes - Talk & Issues 2 10-09-06 05:05 PM
Headlights WelshWop SV Talk, Tuning & Tweaking 3 25-08-05 10:38 AM
Headlights jimmy4237 Idle Banter 2 08-01-70 12:15 PM
