Old 04-10-12, 01:30 PM   #11
oOTomOo
Default Re: Crashed Gixxer - Rebuild
If you want to pop over to halifax with them I can get the DTI and V blocks on them and tell you for sure.
Might take you up on that, If I can figure out how to strap them onto the SV..!
Old 04-10-12, 01:44 PM   #12
It's easy enough
Old 04-10-12, 02:33 PM   #13
Owenski
It's easy enough
ROFL!
If anyone can tell you how to strap abstract objects securely to the bike its this man. Just FFS dont forget you've got a 3ft wide back end when you're trying to filter
Old 04-10-12, 02:44 PM   #14
oOTomOo
They're in for a strip down and a roll on a flat surface followed by a good going over with a straight edge before it comes to that..!
Old 04-10-12, 08:18 PM   #15
oOTomOo
Right..
Had a bit of a strip down, and come to the conclusion that most of the plastic is knackered.
The radiator is leaking (there's coolant coming from somewhere and I presume it's the rad), Front sub frame is broken (we knew that) the headlight is missing pretty much every bracket it came with (we didn't know that).
and two fairing brackets have sheared off.. one from the fork and one from the sump.
Still not convinced about the forks.. oh, and one of the front disks is definately bent.
Bike post strip down..
Questionable forks..
Missing brackets..
Pile o' broken bits
Old 04-10-12, 09:25 PM   #16
joshwalker094
joshwalker094's Avatar
Bargain off the century, what year?
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 04-10-12, 09:30 PM   #17
Scythe92
Looks like an 05-06 roughly?
Old 05-10-12, 08:22 AM   #18
oOTomOo
Yeah, it's a K5.
Had another look at the forks this morning, either the forks are bent or the yokes are twisted. Job for the weekend - Find out which
Old 05-10-12, 09:13 AM   #19
for plastics http://www.virtualvillage.co.uk/moto...or-suzuki.html
Old 07-10-12, 08:58 AM   #20
Dabteacake
Looks like it could be a bargain! Hope it doesn't turn into too much work
Another rebuild hardhat_harry Photos 15 14-03-12 08:13 PM
Will I fit on a gixxer? grimey121uk Bikes - Talk & Issues 8 04-05-11 04:23 PM
Looks like it could be bye to the SV hello to a 750 Gixxer...eek! nictry Bikes - Talk & Issues 53 24-05-10 07:00 PM
DIY Gixxer monkimagic Idle Banter 6 11-11-09 09:45 PM
Gixxer anyone?? trickywoos Idle Banter 0 21-09-07 02:52 PM
