#11 |
As said before Josh, a DRZ's mileage is... flakey at best.
#12 |
Specially since the speedo is dodgy, apparently it's the cable. As when I'm braking the speedo goes to 0 but release brakes it goes up to speed, does this on bumpy roads aswell
#13 |
Just check your battery terminals are tight, your speedo problem may be earth based.
#14 |
Their tight as, and look fine.
#15 |
Also noticing when starting up on full choke, it's smoking abit
#16 |
When was it last serviced?
Has it got a washable air filter? I know when my filter needs cleaning, my bike runs crap and isnt as powerful. |
#17 |
I done the oil/oil filter and spark plug the other day, will clean the air filter tomorrow and try get a multimeter
#18 |
Battery dead again tonight :@ cause I've been busy on it all night, it was getting very hot, could see the fan working, but the bike was smelling very rich of fuel
#19 |
WOW! getting a fan running on a drz is a feat in itself!
Be careful though they're not very good at getting hot dont let it run even with the fan on for too long or you'll seriously fry it. You really cant be certain of anything until you've sorted that multimeter out. As Phil said that would be my priority right now, if its the stator then be sure to upgrade everything to the free power mod (you'll find it online) while you're in there messing about. |
#20 | |
I bought an identical one from ebay at around £1, but £6 postage. Some years ago, but it is still a good 'un
SV1000S K4, Hugger, Scottoiler. Lowers |
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? | maxinc | Bikes - Talk & Issues | 5 | 22-07-11 02:59 PM |
Charging the battery | pben47 | SV Talk, Tuning & Tweaking | 19 | 09-02-10 06:56 PM |
Battery charging and tank raiser questions. | allantheboss | Bikes - Talk & Issues | 14 | 03-02-10 02:58 PM |
Charging the battery | SV PILOT | Bikes - Talk & Issues | 7 | 31-03-08 05:05 PM |
Charging/Battery: | MrMessy | Bikes - Talk & Issues | 8 | 30-11-07 12:50 PM |
