#11 |
Am getting a bit lost, when you say SRAD yokes then you mean for RWU forks? Weren't k4/5 USD?
#12 |
SRAD 750 was USD.
#13 |
Ah I had assumed you meant 600SRAD. So all 750 bits, SRAD yokes, spindle and wheel, clipons?, K4/5 forks (also 750 or 600 as well?), brakes, mudguard. Will I need one of Zoran's new bearings for this? Sorry if this is turning into a Hitler thread but I think so far I've only really heard of people using a complete front end from one model.
#14 |
yes you will need one of Zorans bearings if its a curvy.
try to get TL clipons if you can. off hand i can't remember which ones though. |
#15 |
You need to space discs out 2.5mm, there is a guy makes them i will forward you his email address.
TL1000S clipons are simlar to stock. mudguard K4/5 one Forks 600/750 are same
#16 |
do you still need to space the discs out using the srad yokes. i thought that the srad yokes were narrower.
watch the size of discs k4-5 callipers are shorter but if you use k6> they are taller so you can use 320mm discs but the drawback is it's a nigglymare to get callipers on/off and requires the pads to be pushed back to make it happen. |
#17 |
SRAd yokes are wider, as is wheel. Try fit it all together that is what you need if you use monobloc sumitomos though.
#18 |
ahhh.. i thought they were narrower.. doh
#19 |
Presumably k4/5 calipers and whatever size disc is on the SRAD wheel (310mm?) are good enough without the extra faff of 320mm ones?
#20 |
SRAD are 320.
320 are good enough, think you might be able to use 310's from SV1000 and keep stock K4/5 calipers without spacers. Either is more than adequate stopping power.
Gsxr fork springs | lawson17 | Stuff Wanted | 0 | 05-02-12 01:39 PM |
Uprated front springs and clipons for GSXR | yorkie_chris | For Sale - Other Bikes and General biking items | 0 | 16-12-09 03:18 PM |
sv650 gsxr conversion setup | rallyjon | SV Talk, Tuning & Tweaking | 11 | 17-05-08 10:31 PM |
GSXR-1000 Exhaust setup | curium | Bikes - Talk & Issues | 12 | 27-02-07 08:38 AM |
2002 K Series GSXR 600 Front Suspension setup parts for SV! | Ter | For Sale - SV's and SV related items | 0 | 06-07-06 05:52 PM |
