Old 05-01-13, 12:34 AM   #11
LewSpeight
LewSpeight's Avatar
Default Re: What's my best option for HID?
Wow, i put a really long and decent reply thanking your replies and suggesting the mod could rename this thread to make it easier for upcoming HID'ers. Didnt work, Sod typing that out again.
I've looked at them Musne, just not a fan of the price or the style of the headlight...
What about this?
Old 05-01-13, 12:34 AM   #12
Originally Posted by musne View Post
This is what you need to buy:
http://www.ebay.co.uk/itm/Motorcycle...item415b315acc
All wiring + Ballast included ... However you'll need to buy some things separetly if you plan to switch of the main light completely while having the angel light (sidelight) still on.
That looks ideal. I'd go for that if I were you
Old 05-01-13, 12:36 AM   #13
LewSpeight
LewSpeight's Avatar
i have looked at them, its BorKa's kit on the other forums, just a hell of a lot of money for a front headlight that i dont even like the look of haha.
Old 05-01-13, 12:39 AM   #14
musne
Originally Posted by LewSpeight View Post
What about this?
They look like the exact ones I fitted to my bike... even the same box. At a fraction of the price.
However, the listing says the two colours available are "ANGEL EYE(BLUE) AND DEVIL (EVIL) EYE (RED)"
Both of these are not to my taste to be honest. I fitted 'crystal white' to my bike.
But it looks like you can select which temperature colour you would like your main beam to be.
Old 05-01-13, 12:49 AM   #15
LewSpeight
LewSpeight's Avatar
also, whats the heat like from these things?
edit, a few questions.
How does the projector sit on/around the bulb? Would i have to slot it over the HID bulb and like stick it or do i screw the projector to the back of the main lamp unit and slide the bulb into the unit like normal? If thats the case how do i guarantee a correct angle to light up where i want to see? lol
Whats the heat like from these as a whole? Will it try melt the headlamp unit?
Old 05-01-13, 12:52 AM   #16
fookin hot
The glass on the projector is nearly too hot to touch
Old 05-01-13, 12:53 AM   #17
LewSpeight
LewSpeight's Avatar
Lovely.
Have a re-read of my comment ^ (Edited it)
Old 05-01-13, 12:59 AM   #18
musne
When you receive your package, the bulb will be nicely fitted into your projector already, you don't need to worry about that... Although I did dismantle it to see what's it's like if I wanted to replace the bulb and it's pretty straight forward stuff. Just one little screw that releases the bulb.
Like I said in my earlier message, you have to oven your whole headlight housing after removing the stock bulbs. Then you separate the plastic lens from the black plastic so you expose the are where the reflectors are.
You then simply pop the projector onto the slot where you're H4 bulbs went and tighten them from the back. Again, very easy and everything is provided in the kit, no need for drilling, or making holes.
To make sure your light is straight, you need to switch it on and simply rotate the lens a little until you get a nice straight beam.
Old 05-01-13, 01:02 AM   #19
LewSpeight
LewSpeight's Avatar
Sounds easy enough. Im really thankful for your help! I've been struggling to find any information like anywhere haha
When you say 'rotate to get a straight beam', how dya mean? I get the impression that you can spin the front of the glass and it changes the beam pattern or whatever?
I know i know, i'll shut up.
Old 05-01-13, 01:07 AM   #20
Remember you need to measure the inside of your headlight to make sure a projector will physically fit in there. Doesn't look that big in your pic
BMW finance an option, hmmmmm... etuna Bikes - Talk & Issues 10 05-08-09 10:28 AM
Another helmet cam option. northwind Bikes - Talk & Issues 9 26-10-08 11:06 PM
Is a cut exhaust the best option? webgeeze SV Talk, Tuning & Tweaking 29 15-06-07 08:52 PM
The nuclear option... northwind Idle Banter 79 02-07-06 06:24 PM
Is the SV considered a soft option? pegasus Bikes - Talk & Issues 45 22-01-05 03:11 AM
