#11 |
cool cheers
Sent from my HTC Desire HD A9191 |
#12 |
Unless you're doing serious machining you can "get away with" using fluids other than specific drilling/cutting/tapping oils. Yes they are intended for the job, but not absolutely essential. I have some CT90 which works fine on most general purpose stuff I do, like this except it's a bottle not aerosol.
For mild steels you can use a thin mineral oil, like 3-in-1 or similar, aluminium likes paraffin or one of the few good uses of WD40, brass and cast iron you usually do dry. It's used to stop the tool overheating and prevent welding/pick-up on the cutting edge (I remember drilling a block of lead once without oil, ended up with a large lump welded on the end of the drill bit). If a drill isn't cutting well it's because it is blunt, as the others say. It's worth digging out a table of cutting speeds for different materials/diameters/drill bit spec, something like here just as an example, plenty of others available if you search. Gives an idea of what sort of speeds are suitable.
#13 |
You could try Macsalvor's in Pool, if you still need the proper stuff. They tend to have most things you never thought you'd need but just have to buy!
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan Now: Blue FZ6 Fazer |
#14 |
i never even thought of going there at all.
DOT 5 Brake Fluid | DJ123 | SV Talk, Tuning & Tweaking | 4 | 04-08-11 09:14 AM |
Is this brake fluid okay for the SV? | Scythe92 | SV Talk, Tuning & Tweaking | 8 | 29-03-11 11:13 AM |
Brake fluid - going up! | 5150 | SV Talk, Tuning & Tweaking | 9 | 14-07-09 11:56 AM |
Dot 5.1 brake fluid | DanF | SV Talk, Tuning & Tweaking | 2 | 09-04-07 03:15 PM |
Brake Fluid & Oil | krhall | Bikes - Talk & Issues | 6 | 20-12-06 12:58 AM |
