Old 26-04-13, 09:07 AM   #11
Pricey12
Default Re: Exhaust scratching swingarm?
Originally Posted by quik_d View Post
Yep, bracket is on the wrong side, how loud is that exhaust?
It is pretty loud
It does seem like moving the strap to the outside of the bracket would give more clearance, but most pictures I've seen of other SV's have the strap on the inside. Is there a consensus as to which side is 'correct'. Just wondering...
Old 26-04-13, 09:38 AM   #12
Owenski
I'd argue, if putting it inside fouls the swingarm and outside does not. That would give you your answer for which is right/wrong.
Old 26-04-13, 12:40 PM   #13
Pricey12
Fair point
Old 27-04-13, 06:18 PM   #14
aesmith
Mine's inside (Remus). I think it would look messy outside, but if that's the only way your exhaust lines up properly then you've not got a lot of choice.
Old 27-04-13, 06:27 PM   #15
jmsvuk
The standard SV exhaust on both curvy and pointy was mounted to the outside of the hanger.
Old 07-05-13, 09:12 AM   #16
Pricey12
All sorted now. Rotating the link pipe did not provide enough clearance, so the link pipe had to be bent slightly. Exhaust strap now on outside also.
Have now revised my opinion of Delkevic cans: Sound good and decent price, but fit (at least on curvys) leaves a bit to be desired.
Swingarm bobbin bolt stuck in swingarm BigV Bikes - Talk & Issues 7 12-06-13 12:24 PM
Crash.NET - Hayden scratching head after chatter issues NewsBot News 0 26-10-12 10:30 AM
916 swingarm - is it possible? ger1111 SV Talk, Tuning & Tweaking 9 18-03-10 02:03 PM
Crash.NET - Head-scratching for Hayden and Ducati. NewsBot News 0 03-05-09 07:40 PM
swingarm Nicky S SV Talk, Tuning & Tweaking 35 24-09-08 12:48 PM
