Old 05-06-13, 04:49 PM   #11
PyroUK
PyroUK's Avatar
Default Re: Tank prop and fuse location?
if its a pointy and its had a tail tidy fitted there is a good chance the mount for the fuse box and clip for the prop have been removed as its part of the plough i believe. when my old pointy had the tidy fitted the fuse box was stuck to the inside witha bit of double sided tape (that lasted all of 2 days before flapping about) and the prop was just put in a box with all the bits left over.
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 05-06-13, 11:37 PM   #12
saucysaunders
Wink Re: sv650 prop and fuse location
Originally Posted by muzikill View Post
I's say using a bit of wood as a prop is going to make the tank fall on your hand more than the oem prop which i find is the least bit bendy tbh.
I'd say your using the wrong piece of wood...
Old 05-06-13, 11:39 PM   #13
saucysaunders
Default Re: sv650 prop and fuse location
The tank props are really good, you must be using it wrong.
I would NOT use those hooks on the move myself.
Maybe I am using it wrong tbh, which way up is it meant to go?
Old 06-06-13, 07:39 AM   #14
90 deg bent end stuck into hole in top yoke nut.... flared part on other shallow bent end goes through tank tophat spacer and sticks there.
tank prop badsaboy Stuff Wanted 15 17-09-10 08:35 PM
Fuse box location addicted to rage SV Talk, Tuning & Tweaking 12 21-11-07 12:05 PM
Tank prop Stu Stuff Wanted 2 04-07-06 04:05 PM
Tank Prop splund SV Talk, Tuning & Tweaking 7 03-06-06 10:25 AM
Location of Fuel Tank Prop on K5 Full Throttle SV Talk, Tuning & Tweaking 6 21-03-06 09:58 AM
