#11 |
For 500 id have it. Ask yourself can you do all the work on it yourself?. Has it ever had a service eg. Valve clearances done?
Worst scenario would be getting your dosh back by reselling it, trade in or selling it in bits.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#12 |
I'd have a close look at the sprockets (chains had it), oil cooler hoses and the oil seals on the forks. Lift the front end up to have a look at the front stanchions without preload. They look like the original fork seals to me, at that age and mileage they are past their best.
That front cylinder might be ok, it could be road grime making it look bad. |
#13 | |
What would dropping the engine out possibly achieve?
#14 | |
You could buy something with less miles for £500 Bib's estimate of £300 - £400 is about right
#15 |
Removing the 70k of cack that looks to be in there.
sent from place where even the devil is afraid
#16 | |
Thanks everyone for your feedback.
I'm yet to ride it, so no decisions been made. Quote:
![]() Time isn't so much of an issue, just don't want to buy something that'll cost loads to get looking half decent. |
#17 |
Only the cam cover, something and bugger all that leak. On brighter note that probably indicates the valves have been checked at some point.
#18 |
But if the chain is that dry has anything been done?
Takes minutes to lube a chain, even if you do it on the cheap and brush on gearbox oil. Dry rusty chains put me right off. But at £500 Id buy it, I would only spend whats necessary to make it safe and reliable though. |
#19 |
Well if the chain hasn't been lubed, has the engine oil been changed regularly?
Could turn into a very quick lump of scrap not worth £500 There's better ones out there for similar money.
#20 | |
Evel Knievel
Probably alright for a hack if it's got service history. Wouldn't give 500 for it though and I think he'd be hard pushed to sell it if he refused an offer of 300. |
New here and would like SV buying advice. | Kenzie | SV Talk, Tuning & Tweaking | 10 | 06-03-11 10:00 PM |
SV buying advice please. | Rick K | SV Talk, Tuning & Tweaking | 8 | 05-09-10 08:01 PM |
Advice on buying an SV? | Miss_Undaztood | Bikes - Talk & Issues | 27 | 26-04-10 08:08 PM |
Advice on buying an SV? | muddi | Bikes - Talk & Issues | 44 | 25-04-10 04:28 PM |
buying advice (which one) | hovis | Bikes - Talk & Issues | 25 | 13-02-08 10:04 PM |
