Old 11-07-13, 03:51 PM   #11
SvNewbie
Default Re: Engine Temperature
Fan kicking in is a fairly regular occurrence for me, but I have the lower fairings fitted and I think that doesn't help things. Also ride across London fairly regularly which is, as I'm sure you can imagine, not exactly free flowing traffic.
Old 11-07-13, 03:52 PM   #12
granty92
yeah i dont get much traffic really and i usually know where traffic will be so i avoid it
Old 11-07-13, 05:40 PM   #13
stuR
The fan kicks in a 104 or so usually do as long as you are under that, or at that and the fan is going you should be fine.
Old 12-07-13, 12:00 PM   #14
rowdy
rowdy's Avatar
Default Re: Pointy engine temperature?
From memory and without looking, I think the owners manual states that you should start to panic when the temp reaches 120 degrees, although I would be a little inclined to start to panic before it got that high.
Old 13-07-13, 10:00 AM   #15
adam
back in 2005 when i was a courier using my SV, the temp got up to 110c - the fan wasnt kicking in because the end of a biro had caught in the blades!
no idea how long that situation had been occurring but when i removed the biro cap, the fan worked and no damage had happened, as far as i know!!!!
Old 13-07-13, 02:25 PM   #16
orose
Fan on my 2006 kicked in at 106, but it only ever got that hot in mid summer traffic - keep riding in the countryside and you'll be fine
Pointy running temperature? HomerJ SV Talk, Tuning & Tweaking 6 25-09-12 11:30 PM
Engine temperature fluctuation. FahimW SV Talk, Tuning & Tweaking 5 25-02-12 06:37 PM
Engine Temperature too high? SAMMY650 Bikes - Talk & Issues 8 17-09-10 08:20 AM
Advice needed regarding engine temperature rowdy SV Talk, Tuning & Tweaking 10 13-01-09 04:26 PM
Engine Temperature going up and down Mr Toad SV Talk, Tuning & Tweaking 5 20-07-06 09:10 PM
