#11 |
there is no tickover screw from k7 onwards as its auto.
there is a switch under the clutch leaver bracket with wires going into it. |
#12 |
Sorry just read both replies. Yeh I can start my bike without clutch.
I assume a regular SV cannot be started in neutral without the clutch being in? K |
#13 |
why would someone disconnect the clutch safety on an L0 is beyond me unless you have aftermarket leavers fitted.
no they should all require the clutch to be pulled in. |
#14 |
I fitted aftermarket levers but didn't touch this switch when doing so. Didn't even know it existed to be honest.
Will check when I get home but I'm 99% certain I can start up on just the button. I hope if it's been bypassed it hasn't been butchered and I can reassemble easily. K |
#15 |
Problem solved. Aftermarket clutch lever was pushing the switch all the time.
Put OEM clutch back on and it's now working. Ta K |
Pointy cutting out and speedo random numbers. | Elliott | SV Talk, Tuning & Tweaking | 6 | 10-10-12 03:53 PM |
Restricted Pointy cutting out. | mattysv94 | SV Talk, Tuning & Tweaking | 0 | 03-09-12 10:31 PM |
Pointy SV cutting out? Possible causes? | Sparky160 | Bikes - Talk & Issues | 20 | 02-09-12 12:43 PM |
No side lights, brake lights, rear lights and dashboard lights | Shona | Bikes - Talk & Issues | 25 | 13-11-09 11:07 PM |
03 pointy randomly cutting out? | BomBalong | SV Talk, Tuning & Tweaking | 7 | 17-07-09 12:01 AM |
