Track Days Post up here about trackdays
Old 19-08-13, 09:01 PM   #11
Red Herring
Red Herring's Avatar
Default Re: Best Track Day Tyre
Actually D211 slicks are the road tyre but just without any tread moulded into them. The reason I use them is that they last longer than the treaded version! I go through them at a rate of one front to two rears.
Old 20-08-13, 12:06 PM   #12
mase_tw
Question about buying wheels, Do they have to be off my year and model?
Old 20-08-13, 12:17 PM   #13
jambo
jambo's Avatar
They need to fit your year and model, but these things are often more generic than you'd think.
The easy way to check is to look up the part numbers for your front & rear wheels and see what other Yamahas use the same parts code. You should definitely be looking at several years of the R6, but you may find one or the other wheel appears on something else too. The curvy rear wheel for instance is I think the same as the pointy rear wheel, but the spacers and bearings are different. So they're not quite plug & play, but can be adapted to fit without modification of the wheel itself.
Jambo
Old 20-08-13, 08:29 PM   #14
wideguy
Check brake rotors too. Sometimes you can swap your rotors onto a different years wheel, sometimes not, and if the diameter or spacing are different, you get into moving your calipers around on the forks.
Yamaha used to be very good at using the same parts on different models, sometimes for many years, but it's been a long time since I swapped Yamaha parts around, so I don't know it they still do that.
Old 21-08-13, 12:25 PM   #15
mase_tw
Well the tyres im going for are the Pirelli Supercorsas SC i think!
Old 21-08-13, 02:27 PM   #16
NTECUK
NTECUK's Avatar
There is a pair of super corsa s on the 675 forums , fine in the dry,same size as yours.
Wet they are scary though ...(on the roads)
Old 21-08-13, 02:30 PM   #17
mase_tw
They will only be used in the dry tbh mate i dont think i would risk going out in the wet on my track bike!
Old 21-08-13, 03:13 PM   #18
NTECUK
NTECUK's Avatar
This is his add,
"Pirelli supercorsa tyres Post Number 1 by triple674 » Sat Aug 17, 2013 4:34 pm
Hi is any1 on here interested in the set of Pirelli supercorsa off my new 675
120 ,70,17 front
180,55,17 rear
They have covered 650 miles from new
Still good bit of life left in them 2012 dated
£110 posted to mainland
Thanks James"
I'll pm him if your intrested.They are a great tyres standard on mine.But I'd like the option of rainy days so swopping mine for Michellen.Mine have done 3,700 road miles and are still good(2,600 of mine had 1100 on it when I bought it)
Old 21-08-13, 03:24 PM   #19
mase_tw
Its ok mate ill probs go for a scrubbed set of Supercorsa SC1s or SC2s
Old 21-08-13, 09:54 PM   #20
stuR
Cant comment on personal experience but i know the supercorsas are popular with some. Got em on my gsxr and tho i havent been on it long or ridden it to the extreme...at all....they fell very good. But there agian i only have bog standard tyres from previous bikes to compare to
Track day tyre pressure Small Clanger Racing and Paddock Chat 3 29-03-12 09:54 PM
Track tyre wanted The Idle Biker Stuff Wanted 2 21-09-11 06:26 PM
Track Day Tyre Stockists Tim in Belgium Racing and Paddock Chat 11 28-04-10 10:50 PM
Track day tyre advice please Kneewhere?! Track Days 13 16-08-08 04:38 PM
track day tyre pressures johnnyrod Tyres 12 03-02-06 04:18 PM
