Old 15-10-13, 09:20 AM   #11
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default Re: Welders, start your drooling
Ppfft, I weld like that..... Is something I will never say while looking at those pics
How to amuze an idiot:
Look right-> <-Look Left
Old 11-02-14, 08:43 AM   #12
Brettus
Some more, slightly more appropriate too:
Original article: http://imgur.com/a/366dL
Comments thread: http://www.reddit.com/r/motorcycles/...ed_by_trident/
ah and it is brazing not welding apparently, TIL!
Old 11-02-14, 08:50 AM   #13
Brazing is done at lower temperatures so you get less distortion and less effects on the parent metal.
Old 11-02-14, 09:20 AM   #14
Brettus
Alright then, so what is the difference between Welding, Brazing and Soldering?
Old 11-02-14, 09:46 AM   #15
CharleyFarley
Default Welders, start your drooling
I once soldered a coke can onto the exhaust manifold of my Casal 50, helped along with numerous clips!!!
Pity I dont have photos.........I'd put those "V8" manifolds to utter shame!!!! 😝
"Gas it w###a".........
Old 11-02-14, 10:39 AM   #16
SIII
SIII's Avatar
Talking Re: Welders, start your drooling
Welding is a done by melting the workpieces and adding a filler material to form a pool of molten material that cools to become a strong joint. Usually the same materials joined and the filler of the same.
Brazing is a metal-joining process whereby a filler metal is heated above melting point and distributed between two or more close-fitting parts by capillary action. Used in bicycle frames, plumbing etc. Fillers can be brass, copper, silver.
Soldering is a process in which two or more metal items are joined together by melting and flowing a filler into the joint, the filler metal having a lower melting point than the adjoining metal. Electrical joints, jewellery, etc. Filler is usually a tin / lead mix.
Techie teacher spiel.
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 11-02-14, 02:49 PM   #17
Berlin
Gorgeous! As close to my definition of "art" as it gets. I could have any of those pieces in my house and never get sick of seeing them!
C
Old 11-02-14, 02:55 PM   #18
Brettus
Nice reply! thank you!
Brazing and soldering sound a whole lot alike. I don't get why so many terms exist, seems a little unnecessary somehow. Another thing I learnt today though
Old 11-02-14, 03:19 PM   #19
That might have been done with TIG brazing by the look of it
Old 11-02-14, 03:25 PM   #20
Matt-EUC
Brazing is generally for bigger stuff. Soldering is used for little things like circuit boards and jewellery. Also, soldering uses an "iron" and you use a flamethrower for brazing.
Calling Org Welders! Gordon B Idle Banter 7 21-09-10 05:32 PM
welders flash Wideboy Idle Banter 21 25-09-08 09:18 AM
Exhaust welders nicollow SV Ecosse 6 15-02-08 05:32 PM
calling all tig welders hovis South & West Surfers 17 06-09-07 09:48 PM
Plastic Welders . . Sharpy TOTALSV Ireland 1 06-05-05 07:47 AM
