Old 06-01-14, 08:09 PM   #11
DJ123
DJ123's Avatar
Default Re: Do sintered Pads go "Off" ?
Originally Posted by DavieSV View Post
That shouldn't make a difference though should it?
They might be a different material/compound as the disc gets thinner to prevent the disc from rapidly warping as the material layer lessens. I don't know if this is the case though (similar to tyres)
BMW F800ST
Old 06-01-14, 08:53 PM   #12
DavieSV
DavieSV's Avatar
So then, in the name of science...
My new pads should be here this week.
If I change just one set and they rust just as quick, then that will prove that age makes no difference and therefore they do not deteriorate.
However, if the disc with new pads on stays cleaner, that should prove that they do deteriorate.
I've said with age, but that is not strictly true. Exposure to the elements may be more of an accurate description.
Variables...
Which side?
Should I clean the surface of the disc before fitment?
Should I try to clean the old pads?
DavieSV is offline   Reply With Quote
Old 06-01-14, 08:54 PM   #13
jambo
jambo's Avatar
Default Re: Re: Do sintered Pads go "Off" ?
The material is uniform through the thickness. In this case it's the discs not the pads that are rusting I think. Not all discs are made of exactly the same type of steel. Some types of steel rust more easily than other. The selection of metal was probably made for reasons of heat dissipation, resistance to warping, friction, and cost.
Things rust fastest in warm, wet conditions with a catalyst like salt. Guess what conditions those GSXR/TL discs have been in?
Jambo
Sent without a real keyboard
Old 06-01-14, 09:34 PM   #14
That's the reason why I asked what discs they were.
Ebc discs are notorious for turning orange if you so much as sneeze at them. I can gaurantee they are orange now! They aren't wearing thin either....not even worn in yet
So, Suzuki iron it is then Davie
Old 06-01-14, 09:39 PM   #15
admin
John T
admin's Avatar
Blimey, neither of my SV's had discs go that rusty and that included being left outside all winter.
sent from my Moto G
Old 06-01-14, 09:42 PM   #16
DavieSV
DavieSV's Avatar
But why now?
Why not last winter or the winter before???
Same run to work, same conditions, stored the same...
Old 06-01-14, 09:43 PM   #17
DJ123
DJ123's Avatar
Might be more salt on the roads maybe? Acid rain erosion? More humidity in the air?
BMW F800ST
Old 06-01-14, 09:49 PM   #18
DavieSV
DavieSV's Avatar
It's not just happened today, been like it for last two or three months.
It was just highlighted today after being stood all over Christmas and I had to drag it up the drive to free it this morning.
Old 06-01-14, 09:53 PM   #19
But why now?
Ummmmm dunnoooo
Can't offer any other possibility in that case!
Old 06-01-14, 11:29 PM   #20
All Japanese OE discs are made of materials that do not readily corrode, this is for appearances sake mostly, many older Italian bikes had iron discs that corroded if you parked near a damp sponge, the material of the disc is very important in this question, what are your discs made of?
Single Seat Cowl """damaged""" lechatenetpat For Sale - SV's and SV related items 8 05-12-12 03:03 PM
Do brake pads go "off"? Sir Trev Idle Banter 5 25-02-11 05:24 PM
"33bhp?" Yes "i dont believe you, I'll seize your bike and take you to court" Flameboy SV Talk, Tuning & Tweaking 936 20-10-10 07:06 AM
Time for new Brake Pads - Which are the "best"? sv_rider1990 SV Talk, Tuning & Tweaking 23 14-08-08 12:01 PM
