#11 |
Modern tires are brilliant. If your riding on the street is getting you to the point where tire traction is an issue, you're going too fast.
The place to think about trust in your tires and to explore the limits of their traction is on a track. Once you find out, on the track, how good your (warmed up) tires really are, you can ride confidently on the street at a pace that leaves you a margin for escaping safely from whatever hazards arise. Most of the time anyway... Nothing you can do about target fixation except to look where you want to go. Even when you have a bad feeling that you're going to end up elsewhere, look where you hope to go, down the road, in your lane, past the debris on the road, not through it. Around the car, not into it. Practice it, think about how well it works, because it does work. I have a lifelong bad habit of turning in too soon on left hand turns. (We ride in the right lane here.) If I can see clear road through the turn, I tend to go there, which often takes me too close to the road center, or into the other lane, so I still have to think a bit and tell my self to wait a little before I turn in. Crossing into the other lane is a habit I don't want to have. But I know I have to watch myself and think about it, so I do. Thinking about escape plans as you ride can help. Like, "What will I do if that car ahead suddenly pulls in front of me on the roundabout?", or "What if there's a patch of gravel in this turn that I can't yet see?". If nobody's behind you, you can practice things like hard braking to a slow speed, with a quick turn when you're almost stopped, something that I've needed to do numerous times, and haven't always done successfully. Or practice quick line changes in a turn, often helpful to avoid hitting things that weren't visible when you chose your line. Think you're going to fast to safely do a quick line change? Probably not too fast for the bike or tires, but, if you get that feeling of panic, you were going too fast for you mind, too fast for your confidence level, too fast for your current abilities. Practice. Think. Practice. Learn your bad habits by observing your own riding. Most often when I ride, I'm very focused. When I'm not, I slow down. A mind full of distractions is a dangerous thing to carry with you on a ride. |
#12 | |
It's allot to take on board with those . Yes it's how we should ride /drive But a steady progressive approach is easier to handle
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#13 |
Agree with a bit of tuition but--------a little contrversial--------you had 13 prangs and you say half of them were your fault.That means you had 6 that were not your fault?I dont buy that and think you need to do a deeper rethink of how you ride.There are ways of anticipating trouble ahead and hence avoiding being in the position where a prang happens,even if that prang is not technically or legally your fault.Worth doing an advanced course to learn some tricks for not having that accident.
#14 |
I'd echo the above comments about advanced training. You'll learn useful skillz but also you'll learn a new mindset, whicih it sounds like is what you need. If you're mainly interested in road riding then yes IAM/Rospa is best; there is a whole set of skills to do with sharing the road with other users e.g. cars, horses, roundabouts where things like weather and corner radius aren't your limiting factors. If you want to ride fast on a track then go and do that, but for most people that's in addition to road riding so I wouldn't start there.
In reply to your specific points in the title, target fixation is a problem but both track and road training aim to do away with this. It takes practice though and this can be difficult as it's all in your head. As for trusting the tyres, this is a recurring one and can be tricky to get over. As wideguy says, modern tyres are da bomb. If you want new ones then get some. If checking the pressures before every ride helps you then do this. One thing you can do is use more throttle on the exit and less lean (corner speed) to convince yourself the tyre isn't going to slide. If it does you can roll off the throttle a bit (or use the back brake), if you are using up grip with lean angle then once it goes you don't have many places to go. I'm not suggesting you go out and do doughnuts, but it's a more controlled way of using up your grip and thereby getting a bit of trust back in the rubber. |
#15 |
I suspect your a weekend worrior that wants to get his knee down, thinking this is the fastest route around a corner, when in reality it's much much slower, do a free check ride see if what they say, but you will have to ride as you would by yourself or it's pointless.
#16 |
From a person who suffered badly with confidence after a 30mph off with no injuries, I feel your pain.
Couple of points, IMO, you were riding too fast for the road, I've ridden with quite a few off here and they do ride way too fast for the road, I'm not knocking them but that's what I believe, very good riders but still too fast. I'm not a fast rider, I like a blast but I have backed off my speed in the last couple of years, I've tried to get better at cornering without increasing my overall speed and tried to get smoother. I have considered doing CSS but tbh, deep down, I'm worried if I got better, I'd ride a lot faster, which I know I would, if you ride excessively fast on the road it's just a matter of time before you get injured in a big off, I'm self employed, I can't afford to. I prefer off road riding these days too, I find it more technical with less risk involved. So my advice, get back out riding but slow down, build your confidence back up slowly, concentrate more on the details than the speed. Last edited by Specialone; 14-02-14 at 11:39 PM. |
#17 |
You need two sets of skills to ride a bike well.
One set is all about controlling the bike, operating the controls and basically not falling off. The other set is all about how you control yourself and use your brain so that you don't get into a situation where you could fall off in the first place.... Riding on the track involves 90% machine skills, 10% brain. Riding on the road is the other way around. Advanced riding courses are all about helping you develop the way you think about your riding. If you can read the road and traffic you don't have to be a particularly skillful "rider" to go well on the road. The vast majority of road crashes are down to a lack of thinking rather than a lack of machine control skills, although they do help you get out of a hole if you do make a mistake.... Without sounding to patronizing the fact that you have recognized you need to improve is half the battle, all you need to do now is find a way forward that works for you. IAM and ROSPA groups are the most organized, but they are hard going for some if you don't fit with each others expectations. There are plenty of videos on the net that have a few gems to offer, and even a few tips in some forums.... I've always believed in learning from others mistakes as they are generally cheaper and less painful than making your own, however you have a wealth of first hand experience to draw on. I'd start by really thinking about your 13 incidents. Were they really 50/50 or could it be a case of you assuming the other driver/rider was going to do something... and then they did something else. Good luck. |
#18 |
If you are on a road you don't know, it's most important to ride with reserve.
If you enter a corner at full lean angle and then suddenly realize it's beginning to tighten up, it will be too late to correct. The trick is to go into each corner knowing that no matter how tight it gets, you will be able to compensate with the little extra you have kept back. The same applies for junctions ,or other points were anything can stray in your path(Like sheep,dear etc).Theirs no point in saying ."I had the right of way" .when your in casualty." Keep that bit in reserve. If the worst comes to the worst ,look for a way out ,Not at whats in your path. Practice emergency braking(your know what its like when it locks ,so your have less to worry about it as you try to avoid the kid who just ran out in the road to see his friends). or say Hang that, I'll do track days ,less interference but a black hole of money ![]()
#19 | |
wether you buy it or not, those are the facts. only so many accidents you can avoid with forward planning. stopping at red lights and getting rear ended isn't one of them for starters. |
#20 | |
I can see the trend towards road riding skills cources and I am going to look at doing a ride safe one. also recommended to me by my ex. thanks for your time guys. |
A lesson in target fixation / I need a new top fairing / Hello | Toffee | SV Talk, Tuning & Tweaking | 8 | 11-07-12 11:01 PM |
09 SV650S : What is limiting me - my standard tyres, the bike or my confidence? | Micky26 | SV Talk, Tuning & Tweaking | 22 | 22-09-09 11:41 AM |
Target fixation, and why it's bad... | the_lone_wolf | Idle Banter | 4 | 09-12-07 02:21 PM |
target fixation (are you laughing hehe) | jim@55 | Idle Banter | 30 | 25-11-06 05:19 PM |
Target fixation | Razor | Bikes - Talk & Issues | 2 | 23-05-06 09:13 PM |
