Old 04-03-14, 05:13 PM   #11
L3nny
L3nny's Avatar
Default Re: Warning to all Focus ST Owners!
Sorry to hear about your misfortune
Last 3 cars I have owned all featured chain driven cams for a reason.
2015 GS 1200 Adventure
Old 04-03-14, 05:55 PM   #12
SvNewbie
My flatmate has had some similar misfortune today as well. Bought an old Nissan Primera, seemed in decent nick, quiet, no noises from the suspension few bumps and scrapes but seemed mechanically ok with the exception of a slightly oil leak.
Turns out the slight oil leak is due to a warped head or an otherwise dodgy head gasket.
He's pretty ****ed off.
Old 04-03-14, 07:32 PM   #13
thefallenangel
T**s or tyres = trouble was what an old fitter i worked with told me.
Old 04-03-14, 07:38 PM   #14
DJ123
DJ123's Avatar
Usually a failing/failed pulley will cause early failure of the belt. The belts generally last, its the pulleys that go & cause extra strain on the belt. (failed bearings usually)
BMW F800ST
Old 04-03-14, 07:41 PM   #15
rb8989
Though chains can be worse when they do go.. non interference engines ftw.
Old 04-03-14, 08:20 PM   #16
Milky Bar Kid
Default Warning to all Focus ST Owners!
Does that mean being a lass I have double the trouble with cars then??!
Old 04-03-14, 08:21 PM   #17
454697819
bugger..
they also are aged linked, so its 100 000 miles or 10 for example..
Fingers crossed for you.
Old 04-03-14, 09:02 PM   #18
Milky Bar Kid
Yeh I said that in OP. But it's just turned 7!
I have no idea where I'm going to pull the money from to fix it.
Old 04-03-14, 09:04 PM   #19
DJ123
DJ123's Avatar
Have you done any research on ST forums for premature failure of cambelts? Maybe there was a fault with earlier models in the manufacturing process?
Or see if anyone has had any luck with a good will gesture from Ford?
BMW F800ST
Old 04-03-14, 09:11 PM   #20
Milky Bar Kid
I've had a quick look but it seems to be a pretty unusual thing!
New Ford Focus widepants Idle Banter 29 16-04-13 03:55 PM
Ford Focus or something else? Amplimator Idle Banter 28 01-02-11 10:39 AM
Little warning for Vectra C Owners -Ralph- Idle Banter 16 21-10-09 10:06 AM
Soft Focus Alpinestarhero Idle Banter 28 08-10-09 12:22 PM
