Old 02-06-14, 02:38 PM   #11
jambo
jambo's Avatar
Default Re: How often do you top up air pressure?
Originally Posted by Dave81 View Post
I check the condition of the tires and the pressures everytime I go out, along with fluid levels and check the callipers are secure. Your mad if you don't.
Originally Posted by JulesW View Post
+1
The bike's used daily, so a check of all fluids and tyres every 30 miles/24 hours is a little on the heavy side for me. However, I'd say I aim to check everything about once a week, or if the handling feels any different it'll be one of the first things I check.
Jambo
Edit: If you're loosing air at any rate at all, more than a psi or two in a week, it is worth seeing if you can find a leak. This does not need to be a piece of shrapnel in the tyre, as it can be leaking around the rim / side wall. Sometimes just having a tyre removed, the rim and bead cleaned and refitted resolves a slow leak.
Old 02-06-14, 06:43 PM   #12
tyres every saturday for the sunday run. everything else is a service/inspection which gets done every 3.5k
over a week my tyres can loose 1-3psi depending on the ambient temps.
Old 02-06-14, 07:01 PM   #13
NTECUK
NTECUK's Avatar
You have a oil window. Takes seconds. Miss out and it's days to fix.
Old 02-06-14, 07:04 PM   #14
got me... lol. yes i do check my oil when i check my tyres as i like my engine to be working after the day out.
Old 02-06-14, 07:05 PM   #15
hongman
Well I checked today and it lost 6psi in two weeks which I guess isn't too bad? Just feels like it turns to a pig to handle overnight on day 14 for some reason... Could be placebo I guess.
Sent from my GT-I9505 using Tapatalk
Old 02-06-14, 07:33 PM   #16
NTECUK
NTECUK's Avatar
No 2 psi you can feel 4psi can feel like a boat
Old 02-06-14, 07:43 PM   #17
and 10psi makes you fishtale all over the place.. lol
Old 02-06-14, 08:16 PM   #18
hongman
Maybe it's to do with the weather as well, one min its glorious next day its like a river!
Old 02-06-14, 08:51 PM   #19
Phoenix22
New tires lose a bit for a while then it stays pretty much stable, or should do.
Firstly a couple of runs should form an absolute seal on the rim, secondly; and here i put on my anorack........when you first put on a new tyre you fill it with air, yes? all agreed?
good, air has a mix of molecules, some big, some small.
Rubber is slightly porous so will let out some of the smaller ones? Yes all agreed?
So, you have to top up to replace the smaller ones that have escaped. Eventually you will by the process of dilution have a tyre full of big ones that can't escape!!!
Tyre fitting companies will gladly inflate your tyres with this for about a fiver.
Old 03-06-14, 08:52 AM   #20
johnnyrod
johnnyrod's Avatar
The rubber is pretty thick, I don't think the air "molecules" (i.e. nitrogen and oxygen molecules) can fit through it. Moisture can but that's a different story. Kwik Fit will fill your tyres with nitrogen and tell it makes a difference, it doesn't.
Anyhoo I have always found I have needed to top up bike tyres regularly, but not car tyres anything like as much. No idea why. One guess is that the tyre valve points inwards and spins faster so inertia is trying to press the valve stem. Could be utter rubbish but the observation remains, and I've been riding for a while now you could say.
Ear Pressure irnbrumad Bikes - Talk & Issues 15 03-06-09 10:28 PM
Under pressure - again. HELP! krhall Idle Banter 127 03-11-08 09:52 PM
Help! Low oil pressure? gavinsky23 SV Talk, Tuning & Tweaking 7 06-03-08 06:40 PM
Oil pressure light sk5 Apophes SV Talk, Tuning & Tweaking 13 11-01-08 04:32 PM
Tyre pressure? Rodger Wabbit SV Talk, Tuning & Tweaking 10 24-11-04 12:23 AM
