Old 22-08-14, 09:24 PM   #11
heros
Default Re: ER6 warranty issues.
Just an update, managed to speak to kawasaki direct and the tank + lockset are being replaced under warranty \o/
Old Bikes: 2002 Black Yamaha dt 125, Red Sv650 k5 (naked), Black Bandit 650 k8 (naked), gsr750, er6n, sv650a Current Bike: GSX-S750
heros is offline   Reply With Quote
Old 22-08-14, 09:36 PM   #12
muzikill
muzikill's Avatar
Result!
Sent from my GT-I9505 using Tapatalk
warranty Bibio SV Ecosse 5 15-07-09 08:35 PM
Removing a cat under warranty? andyb Bikes - Talk & Issues 9 11-06-09 05:08 PM
New can = no warranty? Keith1983 Bikes - Talk & Issues 14 24-09-07 11:45 PM
Servicing and warranty issues. DanAbnormal Bikes - Talk & Issues 4 03-09-07 04:02 PM
Warranty 1world2wheels SV Talk, Tuning & Tweaking 1 10-06-06 07:09 AM
