Track Days Post up here about trackdays
Old 06-02-15, 05:44 PM   #11
Markos_46
Default Re: Nearly time for a TD!!
Im doing Brands on 21st Feb - hopefully it'll at least be dry!
Old 12-02-15, 07:50 PM   #12
JonSV
Originally Posted by Bunkle View Post
The Mallory TD is Friday 13th!!
I'm planning on doing Mallory on Sat 7th (£20 more but saves a day holiday) or Fri 13th. Just waiting for new brake lines to arrive so I can get them fitted before booking up. Will do the 7th if it's looking dry, if not I may see you there on the 13th.
I've ridden about 20 miles in the last 2 years and it's 3 years since I've done a trackday, so I may be a bit rusty...
Old 12-02-15, 07:53 PM   #13
dw22
Ill be at donington on the 6th march with NL, not on a sv though.
Old 06-03-15, 03:48 PM   #14
JonSV
Anyone doing Mallory tomorrow? Weather looks good and my suspension improvements seem to be working so I'll be wobbling around with the novices.
Old 06-03-15, 08:10 PM   #15
Bunkle
Bunkle's Avatar
Go at your own pace buddy, let the faster lads crack on and just make sure you enjoy yourself!
I'm jealous as the weather is supposed to be warm and sunny this weekend.
Stick some pics up over the weekend mate.
Track - 2001 SV650, ZX10 shock, GSXR K6 Forks, wheel and radial callipers, full M4 race exhaust system.
Bimbling - VZ Marauder with a 600 Bandit lump
Bunkle is offline   Reply With Quote
Old 08-03-15, 09:44 AM   #16
Balky001
Balky001's Avatar
So how were the TDs this week lads??
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 08-03-15, 12:15 PM   #17
JonSV
Mallory was excellent - dry, warm and sunny all day. I like the track more than I was expecting as well. Bike was good, only problem was occasionally bottoming out the forks under heavy braking, hopefully a slightly higher oil level will sort that. Shame that there weren't any other SVs to play with, by the end of the day I could hold my own through the bends with many of the sports bikes but got a bit swamped on the start-finish straight!
Old 08-03-15, 05:13 PM   #18
Balky001
Balky001's Avatar
Sounds like a perfect day Jon.
Be careful just adding heavier oil without getting it looked at properly. You might need higher rated springs (£80 for ohlins) or just setting up properly/serviced.
JHS Racing is in Bristol still I think, might be worth giving them a call as they used to be a SV specialist (I'm going back to 2003 when I went to them) and if you are doing a few more would be worth the money getting the suspension sorted
Old 08-03-15, 06:14 PM   #19
JonSV
I've already changed the springs, hopefully I just need to tweak the oil level / air gap. My google based knowledge provided a range of levels to start with so I went on the low side on the basis that it's easier to add a bit than remove a bit. I'll top up to the standard level and see how it feels, it was only noticeable a couple of times when I had to brake a bit harder than I wanted to...
I'll probably will get some setup advice once my riding has improved a bit, but will probably do it at a track day rather than a static setup that JHS could do. I got my rear spring from them, they're still doing good things with SVs by all accounts.
Old 09-03-15, 12:31 PM   #20
Balky001
Balky001's Avatar
Well I hope you find a good setting although sooner rather than later
When's you next one!! I need to get a couple in before BRNO end of June, think Snetterton and maybe the Silverstone Int'l some posted details of on nhere a few days ago
Long time lurker, first time poster steady2wheels East Anglian Revolution 10 11-07-13 07:01 PM
long time browser, first time poster in need of help stevo_sv Stuff Wanted 8 01-11-08 01:43 PM
Long Time Reader, first time poster Oli Idle Banter 71 07-06-07 11:32 AM
It’s that time of year again … Renewal time … Blue_SV650S Bikes - Talk & Issues 19 31-12-06 06:51 PM
Good cause time, need your time, not money! Spiderman Soho Massive 4 21-03-05 06:24 PM
